How do I remove The Coolant Level Sensor
venturenot
04-18-2012, 03:53 PM
My coolant level sensor is bad., how do I replace it? I understand that there is a retaining metal wire holding it on. How do I get that wire off?
gmtech1
04-18-2012, 04:21 PM
Just lift one leg of the retainer, twist and pull the sensor out of the radiator. Twist it about 90deg.
Tech II
04-18-2012, 04:47 PM
Also, look at the new one.....you will get an idea how the retainer works.....might need a coolant flush.....if you have contaminated fluid, that would cause sensor failure.....and cause the new one to fail too....
