2003 Honda Accord A/C Low Side Port Leak
J and J Oil Change
03-16-2012, 10:35 AM
I have a leak on the Low Side service port on a 2003 Honda Accord, I have already changed the valve but it is still leaking, any help?
DeltaP
03-16-2012, 06:08 PM
I assume you're using the correct valve core. You might try to lightly reseat the port with a tire type tool. Then install a fresh valve core lubed with PAG oil. Do not over tighten. Other than that you'll have to replace the line. Hope this helps.
