front end
southcarolina864
02-23-2012, 12:56 PM
i ask how to lift my front end . well sumbody told me to put air bags and sum said springs but is it ok to ride with the air shocks with 70lbs of pressure in them on a car?
j cAT
02-23-2012, 02:59 PM
the correct pressure is when the vehicle is level.........
my vehicle it was about 30 psi. that is with a full tank of fuel and the usual equipment on board.
when the snow storms hit I would place about 400lbs of sand in the trunk. then add 80psi to the air shocks. now I will have traction and a level vehicle it worked great. now I have the 4X4 silverado so no more traction problems.
you should not drive with too much air in the rear. keep vehicle level.
it is not OK to drive with that much air things will break because the rear and front are too out of position.
