Block solution? Am i able to use a 400 chevy block to sub for a ford 400
chamblizi
01-10-2012, 03:40 AM
Hi i am phil i want to build my own Ford 400 Cid the only problem is every 400 is now branded Chevrolet or Pontiac Ford has there own 400 and yes its a rare engine block can i use a Chevrolet 400 engine block and make it into Ford based engine?
What are the difference between the two of these engines.
oldblu65
01-19-2012, 10:04 PM
The Ford 400 c.i. and the Chevy 400 c.i. are two totally different engines from two competitors in the automotive world . There is no similarities or interchangeable parts between the two . You may be able to find a Ford 400 in the salvage yards or from sources such as Craigslist or on www.racingjunk.com .Good luck !
MagicRat
01-19-2012, 10:55 PM
The Ford 400 engine had little performance support because it's been out of production for 30+ years, and it never was put in a performance chassis, so there's little interest.
You are much better off building a 351 Windsor engine. It has far more performace parts and support available for it. You can easily build a 351 that will out-power any Ford 400.
Alternately you could build a Ford 460.
chamblizi
01-23-2012, 12:25 AM
as of 3 weeks ago i already decided to build a 351 maybe not a 351w but i am building one also...... i don't want to deal with (FUEL INJECTION EVER)
fuel injection has no control what so ever
carb FTW
carb FTW
