Our Community is 705,000 Strong. Join Us.
98 Jimmy, wont start or shift from park
pitbullvassar
12-28-2011, 08:20 AM
Hey. Got up this morning and went and started my Jimmy for my wife so it would be warm. When she went to leave, it evidently would not shift out of park, so she turned it off. Now it wont shift or start.
pitbullvassar
12-28-2011, 10:19 AM
Also, the key is not stuck in the ignition and the dash light do come on when I put the key in the ignition
maxwedge
12-28-2011, 11:34 AM
Check the battery cables first, are the lights and horn strong? If all this checks out could be the ign. switch, not the key cylinder but the switch itself.
pitbullvassar
12-28-2011, 12:08 PM
Ignition switch is not 100% out of the question, but I actually had that fixed this summer.
I just climbed underneath and sprayed some wd-40 on some of the linkage. Its almost like it didn't make it all the way into park (but it did sit there idling for about 10 minutes after I moved it) so the vehicle does not register it as being in park and now does not want to start. What would cause it to not shift out of park?
pitbullvassar
12-28-2011, 12:40 PM
Horn is strong, lights are fine
pitbullvassar
12-28-2011, 01:07 PM
Also, it is not turning over. Probably should have said that earlier.
pitbullvassar
12-29-2011, 09:40 AM
Just talked to the garage. Evidently it was the Bitsy Solenoid
maxwedge
12-29-2011, 11:47 AM
Never heard of it?
pitbullvassar
12-30-2011, 02:24 PM
The bill says "inspected vehicle and found broken wire at shifter pigtail connector. Was necessary to repair broken wire".
maxwedge
01-03-2012, 02:40 PM
more like it.
