4l60e Valve bodyFishFind 12-21-2011, 10:33 PM Before I do it I am going to check. I have a 1998 blazer 4.3 4x4 that has a 1998 pwm 4l60e valve body. I also have a 1999 s-10 2wd that has a 1999 4l60e tranny. I have the valve body off the s-10. What I would like to know is can I use the s-10 valve body in the blazer?? I know the TransGo Separator Plate FITS: 4L60E, 1996 to 2006 and is the same for my s-10 and blazer but will the actual valve body work also. They are both PWM valve body's. trannyman52 12-22-2011, 10:06 AM they will interchange,,,,only difference would be in the seperator plate,,,but not in this case,,,plate is different for pwm///non pwm...if you use plate that was with the valve body you can't go wrong FishFind 12-22-2011, 10:14 AM Thank you Automotive Network, Inc., Copyright ©2012
