crown vic rear axel wear
rsim
10-02-2011, 12:38 AM
http://http://simoniansawservice.com/AX1.jpgThis is on a 2003 police version This is the 2nd time in 12k miles that this has happened. Do not know which part failed the first time as I had a shop fix it.
This time the axle wore where the outer bearing runs.
See the pictures Please let me know what yoU all think
I also did a hardness test and the one with damage is softer then the other one. i used a file for the test.
So where can i buy hard ones?
Thanks
Rod
http://http://simoniansawservice.com/AX2.jpg
http://http://simoniansawservice.com/BEARING1.jpg
Thanks
Rod
rsim
10-11-2011, 10:14 PM
Smith auto can get me a dorman rear axle for 150.00 and bearing for 29.00
going to use diesel to wash out the oil that is stuck to everything . this should also remove the metal dust. Not sure what to do with it after I get it back together. Sell or keep for a spare. As the replacement I think for 2008 makes noise from 60 to 50 MPH but is quite at other speeds
