03 Neon not turning over at all
mr. fresco
09-17-2011, 11:25 AM
i recently purchased a dodge neon from a friend and he said the spark plugs needed replacing and the starter..... i replaced both plus a new battery, and when I turn the switch foward, i hear the fuel pump turn on and all the gauges work, but the engine dont crank at all... any suggestions?
Chromehero
12-07-2011, 11:45 AM
Let's start simple: double check the connections on the starter. Check the fuses and relays associated with the starter.
The fuel pump is coming on, so that is a good sign that your electrical connections associated with the key switch are all good.
Are the connection at the battery clean and solid?
