AIR DRIED BEEF DOG FOOD
Garrett or 16g turbo
jontierney888
09-07-2011, 02:59 PM
Hey im kinda new to engines. my eclipse has a 420a motor with a garrett t3/t4 50 trim turbo. My friend gave me a 16g turbo that hes not using. So any suggestions if i should keep the garrett or switch to the 16g would be awesome
david-b
09-09-2011, 10:31 AM
The 16g is will have a Mitsu flange on it. There are no Mitshu-style flanges for the 420a unless you make a custom adapter. It's possible, but generally not worth it.
steviek
09-18-2011, 11:31 AM
Yea not going to bolt on. Which is unfortunate because the 50 trim is a bigger turbo. So lag will be more on it then the 16g and since I got a feeling you're not boosting it too high I'm sure the 16g would be able to flow the amount of air you're wanting.
SilvrEclipse
09-20-2011, 12:05 PM
It would be easier to go with a smaller t3/t4 turbo that will bolt right up. The 50 trim is fine as long as you dont mind the lag
