98 buick lesabre tran leakarmy 07-20-2011, 10:38 AM i have trans. fluid leaking through the seal of passenger side drive shaft does anyone know how hard it is to do without a hoist and how hard do you have to force shaft to come out of trany and the proper way to re. and re. the seal. what would be a reasonable price for mechanic to do it. any info would be appriciated thanx maxwedge 07-20-2011, 01:30 PM Check the how to at autozone.com, repair guides. inafogg 07-20-2011, 01:31 PM i have trans. fluid leaking through the seal of passenger side drive shaft does anyone know how hard it is to do without a hoist and how hard do you have to force shaft to come out of trany and the proper way to re. and re. the seal. what would be a reasonable price for mechanic to do it. any info would be appriciated thanx alot easier on a lift(so your standing vs lying on ground)but not to bad. if your familure with removal, poping axle from trans with 2 pry bars keeping joint center will usually come out with limited force. we got 1 1/2 - 2 hrs labor plus parts so 150.00 seems fair the seals are about 10.00 army 07-21-2011, 07:20 AM alot easier on a lift(so your standing vs lying on ground)but not to bad. if your familure with removal, poping axle from trans with 2 pry bars keeping joint center will usually come out with limited force. we got 1 1/2 - 2 hrs labor plus parts so 150.00 seems fair the seals are about 10.00 thanx for info. and a quick response much appreciated Automotive Network, Inc., Copyright ©2013
