oxegyn sensor reads 0 on OBDII scannerventurenot 07-17-2011, 07:01 PM Sometimes when I am at highway speed (55 to 65mph) when going down a hill, if I take my foot off the gas pedal my scanner shows my upstream o2 sensor at 0 and my LT & ST fuel trim at 0. This does not change until I put my foot on the gas and then the O2 sensor starts switching normally and fuel trims begin to change. Is my O2 Sensor about to go bad? I just changed my throttle position sensor, could this have something to do with the problem? lesterl 07-17-2011, 09:13 PM Hows your gas mileage? Any codes pop up? LT fuel trims staing pretty low (close to 0)? The closer to 0 you can stay the better it isnt adding/ subtracting fuel to the mix. venturenot 07-17-2011, 09:25 PM Hows your gas mileage? Any codes pop up? LT fuel trims staing pretty low (close to 0)? The closer to 0 you can stay the better it isnt adding/ subtracting fuel to the mix. Not bad, and not the best it has been No They are at zero along with the O2 sensor under the conditions I have described, otherwise long term fluctuates between - 1 and -6 Yes, but maybe it is staying at 0 because O2 sensor is not giving any feedback. lesterl 07-17-2011, 10:05 PM Well if it is going negative it is subtracting fuel from the mix (leaning it out), perhaps you have a minor fuel leak or something? What is your fuel pressures like? Automotive Network, Inc., Copyright ©2012
