96 lesabre just diedjim2020 04-17-2011, 11:29 AM 96 lesabre just died while driving. Will not start. Codes po107 MAP po108 MAP po121 TPS po401 Any help with this diagnosis would be greatly appreciated HotZ28 04-17-2011, 02:12 PM Do you have spark & fuel pressure? If so, you may have a bad PCM, or any or all of the following: DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage DTC P0121 TP Sensor Circuit Insufficient Activity DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient jim2020 04-18-2011, 07:03 PM Yes there is spark. Fuel not sure. Is there an easy way to check it? HotZ28 04-18-2011, 09:46 PM You can check the fuel pressure @ the fuel rail schrader valve, using a fuel pressure gage. Most of the popular auto part suppliers have the gage in stock. jim2020 04-30-2011, 01:47 PM FYI the car will fire for a split second with a battery disconnect/reconnect. Automotive Network, Inc., Copyright ©2013
