Turbo or SuperCharger
ProShift
05-28-2003, 02:02 AM
Which one should i get Turbo or SuperCharger i want more power and speed? wut do u guys think i should get
Neutrino
05-28-2003, 02:07 AM
turbo all the way....the potential of a turbo is imense.
give us more details what car do you have and for what kind of aplication do you need Fi
ProShift
05-28-2003, 02:09 AM
Hey yeah
it is a 98 integra
Neutrino
05-28-2003, 02:31 AM
Originally posted by ProShift
Hey yeah
it is a 98 integra
well those integra engines are very good to turbo....arbuably the b18 is the best honda engine to go turbo with....
what type of integra do you have? ls, gsr....?
turbo2nr
05-28-2003, 10:20 AM
TURBO!!
NUFF SAID
1
88_SC_CRX_Si
05-28-2003, 11:30 AM
However you might want read this before ENOUGH SAID... hehehehe
http://honda-tech.com/zerothread?id=68242&postid=524784
"Noth'in like Induction..." ;)
ProShift
05-28-2003, 11:45 AM
How much horse power would a turbo give me
Neutrino
05-28-2003, 01:23 PM
since i don't know what engine you runnin exactly i'll say up to stock ~230
reinforced ~400+ maybe its very hard to tell depending on what you want to do and how many dollars you want to spend
turbo2nr
05-28-2003, 02:13 PM
Neutrino look like he has it under control here so ill me moving along..
good job neutrino!
good luck
1
lordvektra
05-28-2003, 04:31 PM
you all say turbo but why turbo over super? what would be the downside of the supercharger?
PWMAN
05-28-2003, 04:37 PM
A supercharger takes away crank horsepower, thus making it less efficient. However, a centrifical SC has much better efficiency rated that a roots blower like the Jackson Racing one. Don't waste your time and money with Jackson blowers, they suck. Also, all you have to do is change the wastegate to up the PSI of a turbo, you have to change the pulley(big pain in the ass) on a supercharger. And lastly, you got the sweet whine of a turbo and the sound of a BOV to go with it - Good times, good times.
PWMAN
05-28-2003, 04:43 PM
Also, if you REALLY want a SC over a turbo, go to this site:
www.procharger.com
They have the biggest gains and are more reliable than a vortech blower. Plus they are intercooled, this is a major plus. You can get a air/liquid intercooler from vortech, but they are insanely expensive. Also, an air/air intercooler is maintenance free. The kit from Procharger is the best SC on the market for your GSR right now hands down. It gives you close to 300 HP on a stock engine, but just think, add a header, high flow cat, and a minimum of 2.5'' exhaust and you will be over 300 HP because the stock exhaust is pretty restrictive.
lordvektra
05-28-2003, 05:41 PM
yeah I was looking at a vortech. Chances are I wont throw in any more boost than what the kit does, I dont plan on putting a ton of money in this. maybe the super and H\E. so super still looks like it would be best for me in the long run. I went to the site and looked at the procharger kit around and really cant find anything with specs or prices only a picture of the kit. I requested a book but about how much is does procharger kit?
ProShift
05-28-2003, 06:53 PM
Where is a good place to get a turbo
Jason_87
05-28-2003, 07:45 PM
I swear i have seen this topic b4 i n the last week,
anyways I'd go Turbo, it takes longer to spool but will give you more speed in the long run.(I Think)
_________________________
New To AF :flipa:
PWMAN
05-28-2003, 09:13 PM
The kit I'm talking about is 4000 dollars, I think the ''tuner'' kit is 3500 but I don't know what that consists of(like if it includes the intercooler). But whats the Vortech cost? Like 3500 without the intercooler isn't it? This is way better than the vortech kit. In the packet you receive in the mail you'll get more info than whats on their webpage. Like for example, their charger is good to 40 PSI - thats like insane. People use these same kits in their Pro street cars running pump gas!!!
FourG63 97GST
05-29-2003, 12:36 AM
S/C 4 banger suck balls IMO
turbo no doubt
to up the boost on a turbo, you turn a switch
to up the boost on an roots S/C, you go out and buy a pulley
you are fwd, turbo lag is your friend. you dont want full boost coming off the line.
ProShift
05-29-2003, 12:38 AM
how do i change the boost pressure ?
Neutrino
05-29-2003, 02:31 AM
on a turbo?...you have to be more specific in your questions.....
wellll with a turbo you use a `boost controer....and btw the coolest is when you launch as low boost so you don't peel out and when you hit second you switch to high boost...
PWMAN
05-29-2003, 10:42 AM
Centrifical blowers don't have full boost off the line, it's roots blowers like jackson racing that have full boost at about 3000 RPM. Centrificals have progressive boost, that is the higher the RPM the more boost you get. So if you launch at about 3000 RPM you are probably only making like 3 or 4PSI boost, it depends on how much you are running. Like if you got a pulley designed to get you like 20 PSI, then you will probably have 6 or 7 PSI at 3000 RPM. But only running the stock boost of the kit(9 PSI) then you will probably only make a couple PSI at less than 3000 RPM.
