Rear air suspension / line is broke where does it go?smackerquacker 04-10-2011, 03:27 PM I bought the Monroe shocks and pulled the wheel off to see that my air line is broke. Where is the compressor or where do the lines go? If I have to pull the tank or something I will go get the shocks with springs and ditch the air. Line is super small, I don't think there is any chance of splicing it. Thanks inafogg 04-10-2011, 04:29 PM the pump is mounted on the right rear corner in front of bumper(atleast on the 97) replacement/repair lines are available what year is the car? Scrapper 04-10-2011, 04:37 PM I bought the Monroe shocks and pulled the wheel off to see that my air line is broke. Where is the compressor or where do the lines go? If I have to pull the tank or something I will go get the shocks with springs and ditch the air. Line is super small, I don't think there is any chance of splicing it. Thanks the lines hook to the pump and other end to shock and you have the 3800 in it. smackerquacker 04-10-2011, 05:09 PM It is a 2002 with the 3800. From what I could see the lines disappeared above the fuel tank and I have no desire to drop that. Figured the lines went to the pump but I wasn't sure how they were routed or where the pump was. Back right corner, huh, guess I need to dig around some more. I called Oreillys Auto Parts and they can't get the lines. OEM only? HotZ28 04-10-2011, 09:41 PM It is a 2002 with the 3800. From what I could see the lines disappeared above the fuel tank and I have no desire to drop that. Figured the lines went to the pump but I wasn't sure how they were routed or where the pump was. Back right corner, huh, guess I need to dig around some more. I called Oreillys Auto Parts and they can't get the lines. OEM only?In case you have not found the compressor yet, it is located under the right rear (passenger side) of the body. BTW, if you meed a splice, all you need is an 1/8" compression union! claimed4all 04-13-2011, 08:14 AM In case you have not found the compressor yet, it is located under the right rear (passenger side) of the body. BTW, if you meed a splice, all you need is an 1/8" compression union! I have spliced them before because I had a bad line. I replaced the fitting and joined them near the pump with a compression union. Cost me under 10$. I called to get the OEM lines and they wanted 180$ for them. HotZ28 04-13-2011, 12:47 PM I personally prefer, and use an 1/8" X 1/8" tube to tube fitting as shown below. This type of fitting prevents the compression fitting Ferrell from compressing the tube and either leaking, or restricting flow. Click Here (http://www.legris.com/Legris_ecom/RechercherReferencesTypeArticle.do?codeActivite=BP&codeGroupe=02&codeFamille=01&codeSousFamille=02&codeTypeArticle=3106&codeFiliale=usa&codeLangue=en_US) for more info. Legris US Distributors (http://www.legris.com/Legris_ecom/RechercherContacts.do?codeActivite=BP) http://www.legris.com/jahia/webdav/site/legris/shared/BP/Images/produits/P_02_01_02_3106.jpg (http://www.legris.com/jahia/webdav/site/legris/shared/BP/Images/produits/P_02_01_02_3106.jpg) Scrapper 04-13-2011, 07:00 PM I personally prefer, and use an 1/8" X 1/8" tube to tube fitting as shown below. This type of fitting prevents the compression fitting Ferrell from compressing the tube and either leaking, or restricting flow. Click Here (http://www.legris.com/Legris_ecom/RechercherReferencesTypeArticle.do?codeActivite=BP&codeGroupe=02&codeFamille=01&codeSousFamille=02&codeTypeArticle=3106&codeFiliale=usa&codeLangue=en_US) for more info. Legris US Distributors (http://www.legris.com/Legris_ecom/RechercherContacts.do?codeActivite=BP) http://www.legris.com/jahia/webdav/site/legris/shared/BP/Images/produits/P_02_01_02_3106.jpg (http://www.legris.com/jahia/webdav/site/legris/shared/BP/Images/produits/P_02_01_02_3106.jpg) i agree with zzz on the compression fiting on leaking i had my brother and law put compression fiting it lasted about 10 mls. then leaked big time. Automotive Network, Inc., Copyright ©2013
