92 5SFE Head Bolt Torque ?Blt2Lst 03-26-2011, 01:16 PM I just received my parts for my head gasket job and included were new Fel-Pro head bolts. Included with the bolts were directions to torgue the bolts to 47 ft/lbs. The factory service manual instructions say to tighten bolts in several passes to 36 ft/lbs, then tighten an additional 90 degrees. I am going to use the FSM procedure as stated above but was wondering if tightening to 47 ft/lbs would yield the same results. I am going to try a test when tightening to see if the additional 90 degrees and the 47 ft/lbs are the same. Any input on this would be helpful. Thanks inafogg 03-26-2011, 01:51 PM i agree i'd go by the factory manual but as you say may be the same out come Brian R. 03-26-2011, 07:38 PM IMO, the difference between the two specifications is in the bolt stretch which results. The factory specifications stretch the bolt to a more precise degree. A 90 degree turn is a much more precise tightening to stretch than the pure torque specification of the bolt manufacturer, since the latter relies on clean or lubricated threads to a degree. Also, a torque spec can be fooling when you have a dirty hole in which to tighten the bolt. This type of hole prevents turning a bolt beyond a certain point because of an obstruction or defect in the threads. I recommend using the FSM procedure and use the 90 degree final tightening. Automotive Network, Inc., Copyright ©2012
