2000 Alero 3400 runs well but coolant passes into oil pan...
ericcfx1984
02-21-2011, 12:31 AM
I kinda though head gasket but it is not showing any other signs... what are the odds of this being the LIM gaskets?
it idles fine, not rough, even has plenty of power... for a few minutes... until the coolant gets low
BUT it does over heat after you drive for a few miles... then I checked the coolant and it was almost 3/4 of a gallon low!
also I noticed that the heater works fine for a few seconds, then goes cold...
I HAVE BLEED THE COOLING SYSTEM
turn out the coolant is in the oil pan... with the oil...
ideas please?
should I do a full head gasket set? or just the LIM set?
or should I source a salvage yard engine from like Pick and Pull for around $200
BNaylor
02-25-2011, 07:13 AM
Start with the LIM gaskets since that is a common problem area. When done be sure to flush out the crankcase to get rid of the residual coolant.
100% free webcam site! (http://showmewebcam.com/?p=0) | Awesome chicks and it is absolutely free! (http://showmewebcam.com/?p=2) | Watch free live sex cam - easy as 1-2-3 (http://showmewebcam.com/?p=4)
tblake
02-26-2011, 09:47 PM
I agree with Bob, this issue sounds like a Lower intake manifold issue to me.
ericcfx1984
02-27-2011, 12:11 AM
well I fixed the oil issue, it is clear a can be... but still over heating...
