95 Yukon engine and tranny swap?
TwoPoint
02-13-2011, 05:15 PM
I just hit 280k miles on my 95 Yukon and decided its best to swap out the engine and tranny before they finally die.
I ordered and received a long block and tranny.
my question is . . . what else should I be swapping out as well?
the list so far is:
upper and lower radiator hose
195f thermostat
fan belt
water pump
fuel filter
air filter
Starter
Alternator
o2 sensor
PCV valve
EGR Valve
plugs, wires, cap
distributer w ignition modual
anything else I am missing?
-fuel pump was swapped out 3 months ago, as were the injectors
2000CAYukon
02-15-2011, 01:13 AM
Motor mounts and tranny mount.
//2000CAYukon
TwoPoint
02-16-2011, 10:37 AM
yep, had those on my list as a check and verify
