cold starting problem camry 1998rubs 01-26-2011, 01:14 PM Hi, When starting the car in morning it was giving me starting problems but last week it was doing grinding noise when press the ignition key, so mechanic recommended to replace the starter so I did and it worked fine but since yesterday it is not doing grinding noise but when I press the ignition key it try to start but stop until I press the accelerator along with ignition key for 3-5 sec and then it starts fine. Any idea if it can be new bad starter or something else is causing the issue? Thanks --Rubs Automotive Network, Inc., Copyright ©2012
