1991 Buick Regal Limited
Tanat
01-23-2011, 03:12 AM
The instrument panel entirely from 200x Buick, the place will rise or not, will have to remodel?
dreager
01-27-2011, 08:35 AM
Попытка используя babelfish http://babelfish.yahoo.com/translate_txt перевести так мы можем понять вас
** try using babelfish to translate so we can understand you.
richtazz
01-27-2011, 12:00 PM
if you're asking if you can install the instrument cluster from a 2000 Regal into your 91 Regal, the answer is no, not without an engineering degree, full wiring schematics, and a donor car for all the different connectors you'll need to adapt, if it's even possible then.
Tanat
02-07-2011, 01:34 PM
richtazz of thanks all you correctly understand. Then prompt how to replace, it is more accurate from what machine, there can be dodge of [serbing] or still something in this kind. My panel is broken and do not know that to make? One additional question relative to electric diagram, with the opening of machine squeaks buzzer then it ceases, also for the light and so forth. It where that now shorted out and it squeaks constantly, prompt from what to begin and give diagram.
dreager
02-07-2011, 05:11 PM
I had a cluster die on mine and got one of same year off Ebay for $60. If you search forum i did a writeup on install. There are 8 screws to get the fascia off and another eight behind that.
Hope this helps
Here is one for from a 1994 $35, Здесь одно для $35, (34,000 miles on it)
http://cgi.ebay.com/ebaymotors/94-BUICK-REGAL-SPEEDOMETER-ID-16180264-CLUSTER-/130381713142?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1994|Make%3ABuick|Model%3ARegal&hash=item1e5b5b0ef6
Я имел группу умереть на моем и полученном одном из тота же год с Ebay для $60.Если вы ищете форум, то я сделал writeup дальше устанавливаю.8 винтов для того чтобы получить фасцию и другие 8 за тем.
Понадейтесь что это помогает
