Our Community is 705,000 Strong. Join Us.
2000 Jimmy Fuel Pump Electrical Connector
Inky676
01-19-2011, 08:59 PM
Does anyone have any info on the part number for the electrical connectors for the fuel pump? When I had my pump replaced one of the pins in the connector got bent and will stop making contact.
I've checked with a number of different parts places, and GMC dealers and apparently the part isn't available, and you can't replace or order that entire harness.
I would rather not put yet another fuel pump in (this would be the 4th, as the problem was always misdiagnosed after the first pump change), that has an alternate connector.
Any help would be appreciated.
Inky.
old_master
01-20-2011, 03:57 PM
The original fuel pump connector was square. It had "issues" with getting hot and melting causing the pump to quit. Most all replacement pumps come with a new connector that needs to be soldered to the vehicle harness. The new connector is more of an oval shape.
http://i561.photobucket.com/albums/ss58/cwhook/HarnessConnectors.jpg
Which one do you need?
Here is a link for the old style connector: http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Motor-Fuel-Pump-Connector-ACDelco_15730209-P_2705_R%7CGRP60004_1100080219___
Here is a link for the new style connector: http://www.autopartswarehouse.com/details/QQChevroletQQBlazerQQDelphiQQFuel_Pump_Wiring_Harn essQQ19962005QQDPFA10003.html
Inky676
01-20-2011, 09:32 PM
Thanks for the links, I just picked it up, and hopefully it will fix the problem, and not have to put another fuel pump in.
