Our Community is 662,000 Strong. Join Us.
Camry won't start
joevit
01-08-2011, 08:41 PM
2002 camry v6. Daughter was driving around all night and when I went out to go to the store, it wouldn't start. There is no clicking like the battery is dead. Just nothing. All electrical works. Is there someting with the security system that needs to be cleared? Any help would be appreciated.
danielsatur
01-08-2011, 08:43 PM
1) Can you turn the front head lights on bright and honk the horn?
If not, the battery needs a charge and load tested.
2) Is this the origninal battery for this car?
joevit
01-08-2011, 09:07 PM
Full power when I turn the headlights on bright and the horn works fine. Any more suggestions?
danielsatur
01-08-2011, 09:20 PM
Did you try another key for the ignition switch?
joevit
01-08-2011, 09:23 PM
There is no click click. Just nothing no sound when I turn the key on.
danielsatur
01-08-2011, 09:30 PM
I thinking a bad starter solenode, battery connection going to the starter, or a bad
ignition switch.
joevit
01-08-2011, 09:57 PM
tried another key same thing
danielsatur
01-08-2011, 10:05 PM
I guess it's not the encrypted key!
joevit
01-08-2011, 10:16 PM
So any other suggestions?
danielsatur
01-08-2011, 10:20 PM
ignition switch.
Is this car at your house?
You might consider a mobile Auto technician.
joevit
01-08-2011, 10:34 PM
Car is at home. What is a moble car technician?
gspservice
01-08-2011, 10:38 PM
You might try tapping the starter sometime this frees it up..
joevit
01-08-2011, 10:51 PM
I'll try that in the morning. Thanks.
joevit
01-09-2011, 07:12 AM
Where is the starter located on a camry w/ V6 engine?
danielsatur
01-09-2011, 02:25 PM
Trace the red postive cable going from the battery to the starter.
If you need a picture, see http://www.autopartwarehouse.com
Lightly tap the starter solenode with a butt of a screw driver.
A starter solenode works like a relay switch, it allows a small current to enable a large current device
to turn on.
danielsatur
01-10-2011, 07:47 PM
Did you get your car fixed yet?
