96 camaro heater not getting hot
skitch2
12-21-2010, 12:55 PM
I have a 96 Camaro and air coming out of all vents but the air never gets hot. Not sure if I have more then one problem going on though because the coolant light stays on but when I check the levels it is full. I recently had to fix the hose that goes from the water pump to the heater core so not sure if I have air in the system and that is causing the problem.
burned
01-13-2011, 12:17 AM
Thermostat must be stuck open. Does your temp gauge move?
skitch2
01-25-2011, 03:52 AM
Yes the temp gauge works normal, it will heat up and then the fans kick on and the temp drops down
valente
01-25-2011, 06:12 AM
had the same problem but with a grand prix.
what i did was to flush the heater core,only the heater core,and its been working fine since.good luck
FastIROCZ28
03-15-2011, 11:48 PM
Had this sort of problem with my 2000 Jeep G.C. I ended up replacing the water pump and low and behold my t-stat had been stuck open for at least 3 years! That explained why my heat wasn't very good and it did everything else you explained with your car, the fans, etc. After I had my new water pump installed and the new t-stat and gasket my heat worked really good then. Sadly I sold her right after that but at least the new owner has heat!
So check that out and I bet you'll find it's stuck open. I'd also look at the heater core and water pump to be replaced too. Especially if they're old.
