Our Community is 662,000 Strong. Join Us.
'04 Camry airbag light reset
dawgznuttz
12-16-2010, 01:55 PM
I copied this from another forum a while back (they're referring to the DLC1 - data link connector under the hood):
Use two short grounding wires, one at TC and one at AB, then
> > With the key ON
> > TC one second
> > AB one second
> > TC one second
> > AB one second
> > TC one second
> But maybe 1.5 seconds, just being pretty close will work though.
> Light should be out. Report back with your results.
I approximated the time between grounding TC AND AB (roughly .5 to 1 sec) and
then held Tc to ground and the light flashed continously..I removed the ground
from TC and Voila' problem solved.I took me two tries....not too bad.Thanks Alot.
port on 04 cam different which pins do i ground
dawgznuttz
12-16-2010, 01:57 PM
:confused:HELP:confused:04 camary reset srs light
Mike Gerber
12-16-2010, 05:53 PM
Try looking in the generation 5 factory service manual stickied at the top of this forum's home page. Here's the link:
http://www.automotiveforums.com/vbulletin/showthread.php?t=497839
Mike
jdmccright
12-18-2010, 10:01 AM
The '04 is a different generation of Camry, plus its on-board diagnostics are more detailed. Thus, what worked for the '92-'95 won't work for yours. I've moved your post to a separate thread to keep the topics separate.
You will need an ABS-capable scanner to reset your light, but check for any stored trouble codes first to see if it is really a false reading. Otherwise, you may be driving around with a disabled airbag.
Welcome to AF!
