how to install sealed beams on 92-96 Grand prix
Olds442Guy
12-06-2010, 08:55 PM
Any direction out there on how the sealed beams are removed / installed for the 1992 - 1996 Grand Prix SE (2 door)? I'm trying to help someone from a distance without seeing the car... Thanks!
richtazz
12-07-2010, 10:07 AM
Olds442Guy, Welcome to AF
I moved your post to it's own thread, as the thread you posted it in was over 2 years old and may not attract much attention.
If this car has the mini quad headlamps, there is a metal retaining ring around each bulb secured by screws that holds the lamps in the adjuster buckets. If the car has the integral headlamp assy's with halogen capsules, they are removed from the back side by turning the lock ring 1/4 turn counterclockwise to release the bulb.
