ECU question
groovetube
12-03-2010, 04:01 AM
Are the ECU units for '88 4Runner 22RE and 22R the same? I have a 22RE that I just swapped out for a newer one,and when I was checking something else, I noticed my ECU is labeled as a 22R. While the donor vehicle is still available,should I get the ECU that came with the motor I put in?
Brian R.
12-03-2010, 10:36 AM
Yes, if you can obtain it, match the motor with the ECU.
groovetube
12-08-2010, 04:44 AM
Thanks for the reply,Brian,I'll do that.
fourwd1
12-08-2010, 08:57 PM
The 22R only has an Emissions module. The 22RE has an EFI module and an Emissions module. Which one are you referring to?
