Map Sensor Question
venturenot
11-24-2010, 12:04 PM
I' ve read that the MAP sensor values should equal the barometric pressure before you start your car. When I turn my key to the on position and check my scanner I always get a value of 103 kpa. When the car starts the reading goes to about 40 (10 degrees above barometric pressure). Does this mean that my MAP sensor is going bad?
lesterl
11-24-2010, 05:13 PM
venturenot
11-24-2010, 05:26 PM
Thanks, I got it. Barometric pressure is measured in HGs (Mercury) and the information on my scanner is in KPA (Kilopascal). So my MAP sensor is almost right on the money for a barometric pressure of 30.
Pressure / Stress Conversion Results :
Amount : 30 inches of mercury ( inHg )
Equals : 101.59 kilopascal ( kPa )
lesterl
11-26-2010, 05:35 PM
What scanner do you have? Some can be set to the Units you prefer......
venturenot
11-28-2010, 12:26 PM
I have an Actron cp 9180. I don't think that you can change the settings on this scanner.
