2000 chevy blazer 4 wheel drive drvers front axlesdcrain 11-13-2010, 07:01 PM does anyone know how to remove the outter boot with out taking the axel all the way off if not how do you get the axel off old_master 11-13-2010, 08:40 PM The boot keeps the grease in and the dirt out of the CV joint. If the boot is torn, the grease is contaminated with dirt and it will destroy the joint very quickly. A split boot kit and a packet of grease is NOT the answer, (the joint won't last). For about the same money you'll spend on a new boot and a joint, you could buy a complete half shaft, (axle) assembly, with all new joints and boots, ($60.00)! There's a fair amount of work involved to replace the axle. Remove the following: Wheel, caliper & pads, caliper bracket, rotor, axle nut, ABS sensor connector and bracket holding the wire to the upper control arm, lower shock mount bolt, separate the upper ball joint from the knuckle, push the axle inward to disengage it from the hub, swing the knuckle assembly out of the way, remove the axle from the differential carrier. You can gain a little more room if you remove the hub assembly from the knuckle, there's only 3 bolts, but it's not necessary. sdcrain 11-14-2010, 10:29 AM already have axel ready to come out mine is not a flanged unit book says to tap it with hammer and block of wood that it has circlip holding it on and tapping it should pop it out where do i tap it , on the back of the knukle where the bearings are or back by the inner boot inafogg 11-14-2010, 10:54 AM you need to get behind inner cv joint where it goes into diff with a heavy screw driver/pry bar to pop it out.keeping joint centered with one screw driver while pushing out with another usaully helps. a drain pan is good to have here as the fluid will drain out sdcrain 11-14-2010, 09:16 PM thanks for all the help guys got both boots changed everything went well once I knew what I was looking for only problem I ran into was on the passenger side it did not have a removable sensor and before I could get the hub wired up I dropped it and the two wires that go into the hub pulled out , apparently they are the ABS sensor wires because now my ABS lite stays on in the dash, but I do appriciate all the help. old_master 11-14-2010, 09:34 PM The ABS sensor is part of the hub assembly, it is not serviced separately. That's why you needed to disconnect it and unbolt the sensor wire bracket from the upper control arm. Oops. ;) Glad you got her fixed up, and thanks for posting back! Automotive Network, Inc., Copyright ©2012
