Fog Lights
GregGP
11-12-2010, 08:41 PM
Does anyone know if there is a good (safe) way to modify the fog lights so that they stay on with the high beams on a 2001 GP GT?
BNaylor
11-13-2010, 07:41 AM
There are a few different methods but none are easy and many would say not worth it for safety reasons. Check out the link below.
Click here (http://www.scacgp.com/mods/flswitch.htm)
GregGP
11-14-2010, 10:09 PM
Thanks, I'll check that out. When you say safety reasons, do you mean that it's not safe for my car, or is it to annoying for other drivers?
tblake
11-15-2010, 08:57 AM
One safety reason is because you ground through the same ground as the ignition relay. If for some reason that relay stopped making ground, your car would die.
If you found a different ground, that might be ok.
