Blower motor and Sway bar Bushings
Bunky1267
10-17-2010, 08:22 PM
I have a 94 Olds Silhoutte (sorry got no resonses in the old forum) I need to replace the sway bar bushings on the lower control arms, the replacements I got are just the rubber bushings, and when I took the originals off the bushings were molded into the straps, Do I need to buy new straps or different Bushings with the straps..
Also my blower motor went bad, (press on type fan) and the replacement I bought doesn't have the hole in the side of the motor, do I need to get a different blower motor or was this hole eliminated ?
LMP
10-18-2010, 05:59 PM
..WEll...Silhouette, APV, Transport.....all the same. Hole:...you mean that hole that carries some air to cool the motor ?......WEll, it was not enough anyway to keep the motor from frying on HIGH. Bottom line: HIGH is for short bursts only.....it draws 25 amps....lots of heat. Continuous operation only on 2nd highest setting.
LMP
10-19-2010, 07:48 AM
About the rubber bushings..ROck AUto's catalog shows them already molded to shape....but if they fit in place, I'd use the existing metal straps....the rubber will take the shape....
