1999 ram1500 transmissionbuffy.mike 09-26-2010, 07:31 PM here is my problem when my transmission shifts from 2-3 gear transmission slips u nless you back off the throttle, other than the 2-3 gear shift transmission works fine ive been told the trans clutch band is wore out any other thoughts? dcspankie33 10-04-2010, 12:08 PM I have a 2000 Ram 1500 with the same trouble but when it doesn`t shift from 2nd to 3rd the tranny does not slip. I have already changed my fluids and filter and the sensor and selenoid in the tranny. Any other ideas to point me in the right directions would be greatly appreciated. dcspankie33 01-11-2011, 01:03 PM It ended up being the transmission bands got hard. Had transmisssion rebuilt. mikefaster 01-11-2011, 03:56 PM Sounds like the front (direct) clutch is worn... Does it also happen in overdrive? here is my problem when my transmission shifts from 2-3 gear transmission slips u nless you back off the throttle, other than the 2-3 gear shift transmission works fine ive been told the trans clutch band is wore out any other thoughts? Automotive Network, Inc., Copyright ©2013
