93 escort won't crank overeltico506 08-31-2010, 04:31 PM The light in cab was left on overnight. Kill the Battery so, it got replace and did not want to crank over. There was no prior problems with vehicle.I don't know what to do? Lights works, but radio does not. I think if factory alarm but I don't k now how to fix it, please help me. AzTumbleweed 09-01-2010, 08:02 AM Have you tried jump starting it ith jumper cables? The replacement battery may be bad. eltico506 09-01-2010, 11:14 AM The battery was tested with a voltage. Meter and is good strong 12vlts AzTumbleweed 09-01-2010, 11:18 AM The battery was tested with a voltage. Meter and is good strong 12vlts It takes amps to turn the engine over. If you live near an AutoZone you can have it load tested. I would try jump starting it. If it starts then you know the starter circuit is good. eltico506 09-02-2010, 10:50 AM well the vehicle did not start, but i try starteding with a starter remote switch and i it was a secess, so thats how i know its electrical from the fire wall back to the ignition. so know i have to figured that part out. AzTumbleweed 09-03-2010, 07:03 AM Then the battery must be OK. Sounds lie a problem with the ignition switch then. eltico506 05-13-2011, 11:27 PM finally it was ignition control switch. the car is all good Automotive Network, Inc., Copyright ©2013
