2002 Nissan Altima 2.5 Starting issues
AutomotiveServWork
07-25-2010, 01:08 PM
Hey Guys! Look I know the common problems but heres what I got.
Car comes in CAM code appeared only. Replaced CAM Sensor (did not replace Crank senor I know they should be replaced in pairs) but was only able to replace CAM sensor because of a customer timing issue of them needing to leave. Replaced cam sensor and car started right up. Car left for 5 days and now back with CAM & CRANK sensor codes. Obviously I need to replace the CRANK sensor whats the possibility changing the crank sensor wont fix this issue. I never had one not fix it but I went through and checked all grounds etc and found no probs can someone shine some advice on this one. I will be changing Crank sensor and going from there just curious.
