Tercel Swaps?CrawlinYota4x 05-12-2003, 09:45 PM can i swap like a camry engine into a tercel. I'm tryin to find an engine to put in one that i dont have to get from japan 2strokebloke 05-14-2003, 03:00 PM O.k. first your going to have to specify which generation of tercel you have. Was it built between 1980 and 1987? those where the first two generations, they do not have transversely mounted engines, so such a conversion wuld be "impossible" Tx685 06-05-2003, 01:45 AM wow I think that cannot happen whats the year of your tercel? kamaxor 06-25-2003, 04:02 PM you can put 5e-e engine from paseo, or 4age from corolla, some people were able to put an mr-2 engine on a tercel, but i can't remember where i read that... Tercel GTS 06-25-2003, 06:45 PM I'm saving the $$$ to get a 3SGTE from a Caldina wagon, 260hp, and the wagon engine prolly won't be dogged. see y'all on the higher side of 11's By the way, there'll be way more mods needed to hold the extra weight and power kamaxor 06-26-2003, 09:30 AM good luck i saw it done on starlet a few weeks ago... so if it will fit on a starlet it will on a tercel... or try putting 3 tc engine on it.. there's this guy who drag his tercel (micheal importa) his tercel runs 9.. d55guy 07-14-2003, 02:31 PM Originally posted by 2strokebloke O.k. first your going to have to specify which generation of tercel you have. Was it built between 1980 and 1987? those where the first two generations, they do not have transversely mounted engines, so such a conversion wuld be "impossible" Is there any engine tranny combo that can be swapped into the 1982 tercel? 4AGZE? 2strokebloke 07-15-2003, 03:23 PM Unfortunately, there isn't a single other car with a transmission like that of the 1980-1987 Tercel's. But, because the engine is mounted longitudinally, like in a RWD car, I've wondered if other engines from Toyota's RWD models could be squeezed into the engine bay. They'd have to be pretty short, the length of the Tercel engine is 21 inches and I'm not too familiar with Toyota's (other than the first generation Tercel) so I don't know what would fit. 82tercel 01-04-2004, 08:47 PM hey would a celica gts motor and tranny be possable in any way? ...and what other toyota rims fit a tercel? celica, mr2 ,any at all? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
