abs & brakelight on no speedo 2000 ramredbaron1 07-07-2010, 07:08 PM thier is no vss or abs signal what could cause this has p0500 & abs 72 code. what could cause both to be 0's. thank you Airjer_ 07-07-2010, 11:58 PM Rear speed sensor? Chris Stewart 07-08-2010, 07:12 AM I agree with Airjer, the wheel speed sensor is mounted on the rear differential housing. redbaron1 07-11-2010, 12:09 PM tried the trans & the rear end sensor the trans sensor made the trans shift nbetter the rear end sensor made the abs & brake light go off.their is still no speedo & check engine light is on with p0500 code. still no vss or abs signal,could this be a com problem between the cab and the pcm. thanks Chris Stewart 07-12-2010, 06:34 AM It's a long shot but disconnect both batteries for 20 minutes then re-connect....kinda like a computer re-boot. redbaron1 07-14-2010, 11:39 PM The dealer scaned it said that it needed to be reset, works fine now. I think the rearend sensor was bad. Does any one know what they are reseting and how. thank you Chris Stewart 07-15-2010, 08:19 AM Thanks for the update. I don't know what they could reset. redbaron1 07-16-2010, 11:18 PM Talked to the dealer the new rear end sensor was defective. still don't know what caused both tran's and rear end sensor to be open no resistance. thanks Automotive Network, Inc., Copyright ©2013
