95 GM gas tank
dapopes
06-30-2010, 01:11 PM
Has anyone ever installed new gas tank on a 95 GM? It looks pretty easy, but I know all too well how those "easy" jobs turn into hard ones!!! Thanks for any help.
way2old
06-30-2010, 05:40 PM
Just try to find new mounting studs for the tank straps. Original ones are snapped off on installation and are just a little short. Usually the straps will not "stretch" far enough to attach the nuts back. Other than that it is fairly straight forward.
dapopes
07-01-2010, 03:49 AM
Thanks WTO. So i guess i make my own mounting studs? As long as I know there IS a solution, I may as well try it! Thanks again
dapopes
07-05-2010, 04:52 PM
I wonder if the small leak has anything to do with the car taking so long to start after sitting a while. Somethin has to be causing it!!!!:runaround:
way2old
07-08-2010, 03:26 PM
Sorry for the late answer. If the car sits a long time and is hard to start, the fuel pump could be leaking off causing it to have air in the lines until it gets "primed" again. A small leak in the tank would not cause a hard start unless it drains the tank. It is dangerous however and needs repaired.
dapopes
07-09-2010, 02:47 AM
Yeah, I already priced one and it's only $210.00 @ Oreilly. Thanks again.
