1996 Grand Marquis gas tank removal
demomantwo
06-01-2010, 12:34 PM
How do you remove the gas tank from a 1996 Grand Marquis?
way2old
06-02-2010, 05:30 PM
Drain it, disconnect fuel lines and wiring, remove the sending unit and fuel pump assembly, disconnect the filler neck, remove the mounting straps. Lower it slowly and carefully disconnect the vents on top of the tank.
dapopes
07-13-2010, 02:44 AM
Let me know how that goes for ya, I'll be doin mine soon too. Sounds like it'll be around 500 bucks to do it myself.
dapopes
07-15-2010, 11:43 PM
I'm curious to know where ur tank's leaking. Mine leaks on the passenger side, front corner. Have you replaced yours yet? I wonder if I can fix mine if hole is small enough?
