what do you guys think?djnoodle 05-04-2003, 10:40 AM I have been thinkin, i know i have at least 10 wires hanging out of my fuse box from all my accesories from alarm to al my interior lights. Wouldnt it be a great idea if someone came up with an aftermarket fuse box that you could hook wires into without it looking all ghetto like mine does? any invetors out there interested? candlaudio 05-04-2003, 12:01 PM hey man just an idea but i got my stuff ran to a toggle switch that has a light on the end of it like my lights are blue so the switch has a blue led on the end of it. and run you a hot wire from the battery to the switch, should be the first prong, then run all the hot wires from your lights to the center prong and the ground wires from your lights to the third one and a single ground to the battery, that will eliminate the fuse box wires, but you want it to be fused right, so get you an inline fuse holder and then you will have all your stuff fused. now the alarm is a little more tricky in that if you run it to the switch it would have to be on all the time so you could prolly stand to have 1 wire running to the fuse box..................dont know if that will help you out on this but thought i would give it a shot. wheel1856 05-04-2003, 06:48 PM course there is space under the dash enough that you could go get a fuse box from a used car, mount it, wire it, and have a whole second fuse box for accessories. depending on how much you are using it for, a good capacitor or second battery might be a good idea. but if you have a lot of stuff like neons, foglamps, alarm, ground effects, those gay-ass washer lights, etc. couldnt hurt. could be neat to run your amps through too, put the amp on a dash switch to cut the power when passing cops or driving through neighborhoods. could be done, may not be worth it, but could be done. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
