1990 S-10 Tahoe Pick-up(2.8 engine)ceecee1968 05-12-2010, 10:02 PM Check gauges light came on and seconds later the pick-up cut off. The fuel is not reaching the injectors. My husband replaced the 2 relays for the injectors but the gas pump is not making a noise.. He also changed the fuel pump but STILL no noise. Could anyone give us advice on what we need to do or check... MT-2500 05-13-2010, 08:23 AM Check gauges light came on and seconds later the pick-up cut off. The fuel is not reaching the injectors. My husband replaced the 2 relays for the injectors but the gas pump is not making a noise.. He also changed the fuel pump but STILL no noise. Could anyone give us advice on what we need to do or check... Check all fuses and power feeds first. MT-2500 05-13-2010, 08:37 AM No relays for injectors and only one relay for fuel pump. EMC-1 fuse powers injectors. EMC-B fuse powers fuel pump relay. ceecee1968 05-13-2010, 11:54 AM thanx and I will get back with you.... MT-2500 05-13-2010, 12:06 PM thanx and I will get back with you.... You are welcome. Let us know what you find. Automotive Network, Inc., Copyright ©2013
