95 izuzu rodeo 2.7 fills with water
rjinmt
04-04-2010, 10:25 AM
as soon as you put water in it, it fills the engine! does this have a water pump that is in the engine parts or is this just going to be a head or intake issue?
Cat Fuzz
04-04-2010, 03:30 PM
What do you mean that it fills the engine? Do you mean the cylinders are filling up with coolant?
BTW, you have a 2.6L if it's a four cylinder.
rjinmt
04-04-2010, 07:41 PM
it fills cylnders and block. you put in 4 gallons and you drain the oil and you get oil plus 4 gallons I have never worked on an izuzu so I am not to sure what to expect out of this thing, it was given to me for fixing another car
Cat Fuzz
04-04-2010, 09:39 PM
Cracked head, blown head gasket or cracked block.
rjinmt
04-05-2010, 08:32 AM
are the heads hard to pull?
Cat Fuzz
04-05-2010, 10:45 AM
Depends on your skill level. It's quite an involved job. You do have a 4 banger, right? There is one head on a 4 cylinder.
