View Full Version : Performance
- turbo sytem
- rb26 t28 turbos
- Diagnostics
- Mustang vs Skyline round II
- Skyline Vs Mustang
- HKS Intercoolers
- airflow meter
- A few questions
- RB20DET to RB25DET Engine Swap and Q's
- Skyline on 2wd dyno
- GTR fuel pump
- Anyone using a single turbo GT-R as daily driver?
- Carbon front hood
- Disturbing Noise
- hks or blitz bov
- Spark Plugs
- HKS 2540's
- OGURA Clutch ( O C R )
- Dyno
- GTR34 ( GT turbo )
- bleed valve
- RB20det injectors
- tech n car
- Ceramic Turbo Upgrade
- Ceramic Turbo upgrade
- blitz dual sbc
- auto to manual converting ?
- Tranny
- Optimax no good?
- Auto tranny slip? R33 GTST
- Td06 on an rb20det?
- Clutch Rattleing
- Misfire?
- Quick R34 ATTESA question
- ACDC GTR made 407kw @tw
- Offset and spacer info needed.
- Quoted $350 ...too high ?
- Instructions For a Cheap Home Made Octane Booster
- Dump Pipe With Seperator For The Wastegate
- turbo
- standard R33 GTR wheels or a set of Nismo (Rays) LM GT2 on a R32 GTR. Advice needed!
- Acceleration problems
- Wheel sizes with R32 GTR
- Max Boost With Std. Intercooler
- Dump Pipe Designs?
- Links For Electrically Assisted Turbo's (WHAT LAG!)
- Slow r33gts25t
- R32 gts-t ECU re-mapping?
- ice performance ?
- Boost gauge stops working !
- Bhp
- gtr turbo shuffle ?
- gtr cam gears
- Can you remove resonator from HKS Super dragger?
- Is buying Apexi S-AFC worth it?
- Transmission
- Will a Nismo twin plate clutch from r33 GTR fit an r32 GTR
- RB26 in R32 GTS4
- 1/4 mile times on a manual GTS-t?
- Lowering temparature in the boot
- Minimum thickness of brake rotors?
- Cleaning a Intercooler, and Plugs Fowling
- Thermo Tec Exhaust Wrap
- Splitfire coil packs for RB20DET
- Apexi AVC-R Setting
- Type of Tyre to Buy for GTR
- HKS superdragger vs Apex'i N1?
- Too much Shuto Expressway!
- turbo????
- The right way to hone?????
- What kind of MPG does a R32 GTR get?
- Which exhaust?
- Boost Problems??
- Carbon fibre prop shaft
- how much will I pay for power
- ? 240 to gtr
- Blocking Off Hole For BOV
- Shift Indicator
- Ebc
- Manual vs Auto~
- Tell a Supra owner about the smaller HKS twin setups
- So, what ECU's are you guys using?
- speed cut
- Big Single or Twin for GTR???
- turbo questions
- is it this simple?
- R33 GTR Stock Turbo Good or Bad 4 2.0ltr
- Injectors
- just installed boost gauge
- how to launch start?
- Roto master t04b35 Turbo
- BOV mounted on intercooler pipe
- VTC solenoid?
- Boost solenoid?
- High octane fuel locations
- Just fitted turbosmart controller
- ECU resets
- Hicas
- Chips
- Low torque at start
- RB25DET internals strength?
- Where can I find?
- Hicas
- Rapid climb of water temp
- Fuel controller / Timing controller
- Factory boost guage aint wking
- Do i need an aftermarket BOV??
- GTS4 or GTs-t
- Ethan
- What turbo do people with rb20, and have 200rkw
- Wiring a R31 GTS auto-spoiler
- Water Temp. on Power FC
- R33 GTR and Boost solenoid.
- Boost Issues
- Does any one use a short shift kit on a R32 GT-R
- Adjustable Fuel Pressure Regulator
- Cat removal
- BOV noises
- What gain can i get from turbosmart boost controller?
- sprint results from Qld Raceway
- Actuator Problem = Low low Boost
- NA perfomance mods
- Power Porting, Heads, Manifolds, Turbos
- Dirty Driving
- Anyone using SAFC without an ITC?
- Choice Mods
- What Pod Filters do you use?
- E.C.U. / Fuel
- Position Of O2 Sensor on R32 GTS-T
- Mesh Removal From AFM = KW Increase?
- RB20DET/RB25DET fuel pump
- CHEAP boost control for R33
- GTS to GTS-T cam conversion?
- De-limiter
- Thermo-Wrap for wires/hoses
- fuel smell in car
- De-Limiter
- gts-4 Auto to Manual
- wastegate actuator?
- Z32 AFM on R33 GTS-t
- Gts Hr32 Rb20de
- settings
- Stall and hesitate problem
- injector cleaner
- 02 sensor
- R32 GTS-T power up (the quest)
- check light
- Help with tuning and Tial wastegate
- Intercooler size?
- higher psi=faster?
- plenum mods
- removing factory boost controller?
- Engine Stalling
- Exhaust, filter, body kit etc
- turbo timers illegal
- Turbo Timing
- Power Drop!
- hks VPC ?
- what is my turbo?
- R33 gts-t v's S14 200sx stock
- R33 Speed limiter..how do I remove it?
- R32 GTR injector specs
- !!WANTED!! - info on cheap r32 gts-t mods!
- auto to manule
- safe boost for rb20det??
- Alcohol/water injection
- Hicas Problems?????
- Detonation!
- Who is selling Sard BOV's in Auckland, NZ
- what is this switch
- Weight reduction on a road car
- Cheap Blow Off Valves
- DIY for dummies
- How To Read Your Factory Boost Gauge
- an early 2 psi...
- Clutch
- HICAS problems
- boost gauge
- Haltech E6K ECU?
- RB20DET power-up mods?
- STD R32 Skyline Manual, When Does Boost Develop
- RB20DETT Over Highflowed Single!
- Rb 25 Airflow Meters Wanted
- Shift Light
- problem s with my conversion.
- Max Safe Boost on R33 25T
- R32 Speed Cut.
- Install of BOV
- Performance cam makers.
- Intercooler
- I Posted 1st
- new intercooler
- Driveshaft queries
- Autometer Phantom Series
- Brendon - Air filter first?
- Free Horsepower II.........
- BHP is that flywheelHP or RearwheelHP
- Apexi AFC
- how much power???
- Going nuts about nuts
- What mods should I do? (Australia)
- heat shield divider
- Help
- cryo'd gearbex internals - R32
- Rebuild thoughts.....
- Any GT-R owners running a single turbo?
- Is The RB 26 DETT a very good Engine ??
- Pulleys came in!!
- What is the best Mod a Skyline can have?
- Veilside CE ?
- HKS ETC - it works!!
- Carbon fibre Parts For GTR
