Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Toyota
> Highlander/Highlander Hybrid/Kluger
View Full Version :
2006 highlander 4wd rear diff drain plug part # ?
I fixed a Highlander 2k rpm stumble, heres how.
2005 Highlander Limited Radio question's
Water Pump and/or A/C Belt squeals
Used Hybrid - Things to watch for?
Unusual tire wear on HiHy
07 Highlander, abs, trac and vsc lights on???
Car won't start.
White Smoke just at start up
Caliper Bolt
engine check and VSC lidht came on
02 Highlander ride quality
Camry wood trip Steering for Highlander
2001 Toyota Landcruiser Lost Key
Vsc,abs,brake lights on after r&r rear brakes
Help:Problem programming 08 highlander fob
Help diagnose my trouble codes
Stupid question... 4WD
What is the Best Alarm for Highlander ?
2008 Toyota Highlander Key Fob Programming
Replacement of one tire...?
How worried should I be?
Not all Key fobs are created equal!! Look if your having problems programming.
2001 Highlander DTC P0171, P0174, VSC & Trac light on
RR Brake light
09 highlander made in China
2003 Highlander V6 Help
Looking at '09 Highlander
Help
Highlander front bumper cover
Timing belt question?
master key
Tire Mystery
2004 Highlander power steering help
Gear Oil Difference
'03 Highlander temp control problems
'01 Highlander CEL P1130 now P1150
2006 V6 with Driver Seat noise
2003 Highlander info
Best Oil Filter Brand
iPod for '07 Highlander
2004 highlander maint req light
New HiHy
Sirius Satellite Radio for 2007 Highlander Hybrid?
Speed Sensing Auto Door Locks?
Hybrid problem - died on the road
Tire Wear
Rattle from passenger front wheel?
VSC, TRAC light on
a/c shut off
2005 Hylander has smoke from under the hood
Check Engine Light
2007 Highlander Hesitation & Hard Down Shift
Highland Hybrid rattle
Adding Horn to '04 Toyota Highlander?
Check Engine Light on Highlander
Squeaking coming from steering wheel
Rough ride & poor snow/ice
Lock/Unlock when put in gear.
Lookin for a rear cargo area shade for my 2001 Highlander in TAN
Oil filter change
CEL connector location 2001 Highlander
LED tail lights for '05 HL's
Rattle from the glove box area?
Toyota Approves Use of 0W-20 and 5W-20 GF-4 Oils
2005 Highlander opinions??
2003 Highlander spark plugs
Dealer offer on maintenance
Changing engine air filter on 2004 Highlander
HELP! Lost the main key to a 2003 Highlander
Similar Engine and trans. to 6cyl Hilghlander
2002 Highlander new brakes, rotors & tires
How to get better perf. out of 4 cylinder?
Highlander Keyless Entry Programming Modes
2003 Higlander rear bearings
highlander repair manual
Tire Sizes
2003 Auto Lock/Unlock?
2005 Highlander key
highlander purchase right now!!!!
2004 Highlander Started Stalling Around 32k Miles, Dealers Useless, Please Help!!
HIGHLANDER STARTED STALLING AROUND 32k MILES, DEALERS NOT HELPFUL. HELP!!
Looking at brand new Highlander, need some opinions please!!
New wheels, getting pressure warning light???
where i can get da eye lids for my highlander?
Who's got a hybrid Highlander?
Honda pilot or Toy highlander
'02 Highlander PowerSteering Fluid Flush
Oil Filter In '05 Highlander
thinking about a Highlander
Programming a new key with only the Valet Key
I want to flush the ATF fluid
Toyota Classified Forum
Highlander Rattle
taillight wiring colors for trailer hitch
De-badged Highlander
XM Radio - Aux input on OEM Radio?
How to reprogram keyless entry for Highlander 2004?
Road salt in engine compartment!
ATF transmission fluid change highlander Type IV
pros and cons on the highlander?
VSC light
whistle
2004 Highlander transponder key programming
Heated seats
Vibrations
Skid Control
Buying New Highlander
Gas Grade?
Change the miles on km.
03 highlander noise like rubber squeaking
Aftermarket parts
looking for a 02-04 highlander center console
clunking/rattle-passenger side rear-2003 highlander
V6 belts
OEM Fog Lights.
'02 Highlander Engine Vibration in Reverse
Steering Wheel Shake
Will Highlander fit 3 child car seats?
hey not happi wit brakes
Drivers seat
highlander mud flaps guards
Check Engine Light / Highlander
4SALE: Rims / Wheels & Tires Toyota RAV4 RAV 4 HIGHLANDER SIENNA CAMRY SOLARA PREVIA
buy vs lease question, any thoughts anyone?
Highlander rear wind deflector
Retrofit a 2003 mirror with temperature sensor
Install CB Radio
Valve Noise
Keyless remote programming for Highlander
Can your retrofit the stock nav of the 04 into an 03?
Re-Torque driveshaft bolt
Taking Off Door Panel
Any Highlander Owners?
First One to post
Automotive Network, Inc., Copyright ©2012
