View Full Version : Aspire
- Axle removal
- P0470 and PO340 Codes 1997 Aspire - EGR and CAM sensor?
- tranny swap
- cigarette lighter/ power outlet quit working, wheres the fuse?
- Stickshift sloppy
- Airbag flashing lights code 32
- need help with a 1990 Ranger
- manual shifter falling through floor
- Resurrecting my econo-car
- CV Joint
- oil leak
- ford aspire 95 chip
- 1997 Ford Aspire Parts Needed
- The shifter
- Wont turn over
- My 96 aspire starts but wont run...need help plz
- How to Fix A 95 Aspire Manual Trany
- What Other Tranys are Compatible W/95 Aspire
- curious
- Check engine light still on
- Control Arm Bushing
- wheel bearing problem - help!!!
- 95 Aspire problem
- I pulled the plugs on my aspire and..
- I pulled teh plugs on my aspire and..
- Aspire White Paint code
- Starter Trouble
- Oil leak
- '96 Aspire for Sale
- Loud Humming from the Front
- My aspire is stuck in reverse! HELP!
- 97 Aspire factory service manual for sale
- Noise Under Shift?
- 95 aspire, noise behind dash
- 97 Aspire Parts Car
- instrumentation lights HELP!!!
- 1994 ford aspire
- my dad broke something, help?
- 96' Aspire Dashlights
- 97 new owner
- Tranny Trouble??????
- 95 Aspire any good ............
- Screech in reverse
- aspire parts
- 1994 aspire, leak and wheel bearing
- Rear window defogger
- 1994 Aspire Vacuum lines/egr
- '97 Aspire has blown 2 transmissions (going to junkyard!)
- blinker dashlights tailight problems
- blown transmission
- bright headlight operation
- Gross Polluter
- newbie, need aspire service manual
- New Aspire owner with questions.
- Speedometer cable & Gear
- 95 Aspire A/C relay location?? Help!
- Aspire Bad Idle
- Sputtering when hot
- used engine
- Free Ipod
- Aspire Bodykits?
- cam seal
- 96 aspire
- 1994 aspire
- Manual tranny problems
- Wheel Bearing Replacement, Cant get nut to loosen up
- Front Crank Seal
- McFixem
- Customized Aspire??
- engine burning oil bad
- Funny Noise
- 97 AspireFor sale parts or whole
- Clutch
- A/C Relay
- electrical problem AC?
- I know I'm not out of Gas..
- oil leak
- Help
- 97 Ford Aspire 4 Sale N. New Mexico USA
- Fastest aspire on the planet
- Aspire Oil Pan
- engine swaps
- Blinking Check Engine when accelerating through 75
- Head On Collision Caused Fire
- Engine Swap In Progress
- Loud clicking during a/c !!!!
- Also, Installing front stereo speakers
- '96 Aspire Horn Location?
- Can't Get stereo wired in corectly
- Replacing Check Engine Light/Removing Dashboard
- Transmission problems?
- Interchangeable starters?
- 97 Aspire - idles high when A/C running
- Ford Sale!
- Need rear reflector lens (red)
- Backwards Flywheel?? (94, 1.3L, Automatic)
- airbag cover
- airbag light
- radiator flush
- couple things
- steerin wheel again
- Steering Wheel Mod Plz Help Me!!!!????
- replacing oxogen sensors
- !!!!95 ford aspire parts NEEDED!!!!
- syptoms
- 97 Aspire
- Need help on shift lever
- Still bad gas mileage about 25
- Im Getting 20 MPG in my 95 aspire WHY?
- EFI to Carb
- oxygen sensor
- make it a sleeper
- Changing tail lights
- check engine light
- Aspire parts car for sale
- clutch replacement
- assfire
- 97 Aspire shifting problems
- Pimpin Aspire Video
- 96' Aspire: Tail Lights, Running Lights and Dash backlights not working
- Airbag codes
- 1994 1.3 fuel system specs needed
- In Need of a Transmission
- need help replacing part
- 95' parts or whole
- Body Kit???
- Parking lights will not turn off
- stereo reciever installlation
- Can't Figure it out, Can anyone help
- 32 MPG??? whats the deal?!?
- Need some help
- flashing check engine light
- what have you passed
- performance specs
- are there any mods for the aspire?
- changing light bulb
- 94 Aspire for sale.
- Haynes Repair Manual For Sale
- engine replacement
- Axles
- 97 ford aspire
- Aspire wont friggin' start!!!
- Aspire
Automotive Network, Inc., Copyright ©2012
