Our Community is 662,000 Strong. Join Us.
View Full Version : Thunderbird
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12
  1. Color code for air cleaner?
  2. 89 ford v6 turns over but no spark
  3. 61 thunderbird ac diagnosis
  4. 1966 Thunderbird History
  5. turbo coupe question
  6. 95 tb 3.8 charging/battery issue
  7. 1997 ford thunderbird 4.6 v8 hard starting
  8. 95 tbird with an electrical problem
  9. Dash lights
  10. 93 TBird for sale need head gasket
  11. Another rim question
  12. Need to find this wheel! HELP!
  13. Change color of guages?
  14. PCM/CCRM grounding issue?-fuse #13 blows
  15. drive shaft bolts on 95 3.8
  16. 95 tbird stranded huge puddle of tranny fluid
  17. Problem with Instrument Panel Guages
  18. 1997 Thunderbird LX 4.7L - Does anyone have a pic of the throttle body fully connected?
  19. How to check ball joints on '97 Tbird...?
  20. Vibration 1996 Thunderbird
  21. 1964 thunderbird
  22. 91 Tbird braking problems
  23. 1994 lx need new radiator and brakes
  24. Looking for wheel. Please help!
  25. 3.8 supercharged tbird valve covers needed
  26. 88 thunderbird turbo coupe starter relay
  27. 87thunderbird problems starting
  28. 95' T-Bird braking issues.
  29. A/C blows HOT air
  30. Sensors from junkyard?
  31. All Injectors do not get ground from PCM.
  32. Possible shifting problem in trans
  33. Instument guage problem
  34. 1988 Thunderbird 302 HO
  35. 96 t bird bogged out no start
  36. ford
  37. Tranny experts please
  38. 93 Thunderbird will not start
  39. 97 t bird trans problem
  40. 95 transmission problem
  41. SWAP: 302 HO into 93 LX?
  42. 90 SC Flashing headlights/odometer
  43. New owner. Questions
  44. 95 tbird issues
  45. '97 T-Bird Check Engine light on
  46. How to unlock the steering wheel on a 1981 Thunderbird without a key?
  47. rear diff gears in 90 thunderbird supercoupe
  48. 88 Tbird radiator fans will not come on at all. overheats
  49. 1957 ford thunderbird convert...help!!!
  50. 95 4.6 v8 T-bird multi-issues
  51. '96 Thunderbird Wont Accelerate properly
  52. 94' t-bird rough idle with P1131 and P0171
  53. '85 Thunderbird Won't Start
  54. 1994 Thunderbird Heater Core
  55. 2002 Tbird Warm air of heater becomes cool
  56. Timing Belt Problems
  57. 95' thunderbird not starting
  58. 97 3.8 V-6 Prob - Trans, or Engine?
  59. 1986 Thunderbird Special Edition 5.0L Mustang Engine
  60. 97 cougar engine and 95 tbird ecu
  61. My wagon stutters on hills
  62. Brake experts please!!
  63. Thunderbird and weird noise
  64. Check Engine Light blinking for 1 minute
  65. '85 Thunderbird Information
  66. '95 T-bird EGR valve. Help!
  67. 3.8 oil pan gasket
  68. 97 Thunderbird AC problem
  69. Camshaft Position Sensor on '97 4.6
  70. 1993 Tbird power window problem
  71. Need OBD-II Tester
  72. Ford Triton V8 engine spark plug blowouts
  73. 90 tbird door ajar light stays on but interior lights go out
  74. Shifter button Doesn't push in
  75. Odometer quit & now have to jump solenoid
  76. Question about Opera windows...
  77. 1979 Thunderbird Dashboard lights won't come on...
  78. 1972 Thunderbird spark plug gap
  79. i need egr tube for a 90 supercoupe!!
  80. ford thnder bird
  81. No start
  82. Issues.
  83. engine swap
  84. '94 t-bird 4.6
  85. 95 Tranny Problems
  86. No gas
  87. 1997 T bird wont start no spark
  88. seat covers for supercoupe
  89. 90 tbird sc brights on but very dim when headlights are turned off!
  90. 89 tbird 3.8 to 5.0
  91. 5.0ho 91 T-bird Stalls
  92. power steering pulley install
  93. can remove water pump on 97 v6
  94. strange growl
  95. 90 thunderbird sc headlights flicker on and off
  96. The Best Performance Module And Chip
  97. 90 tbird sc runs great but stutters when i hit the gas to hard?
  98. 10 % over drive pulley rubs supercharger snout and slides on by hand
  99. 95 thunderbird Can't get out of park!
  100. 86 Tbird died
  101. 95 t-bird will not stay running,help!!!
  102. 93 tbird 5.0ho stall and other issues
  103. high pitched noise when Engine revs are 3000rpm
  104. starting/ warm idle issues
  105. 1994 4.6L oil pressure issues (possibly severe)
  106. BEWARE of Otis Ford,Inc. (NY)
  107. Upper control arm/ball joint help
  108. engine break-in
  109. 1990 tbird wont start
  110. 93 Thunderbird help
  111. '95 T-Bird 4.6 V8
  112. 88 t-bird 2.3l turbo coupe
  113. needhelp! with 95 thunderbird with a lot of white smoke coming from exhaust.
  114. 3.8 head changes. help?
  115. Ac blowing hot air.
  116. 3.8
  117. 1987 T-bird Wont start
  118. (90 sc) my car idle is going up and down while i am not moving!!
  119. 96 Tbird will engine will not shut off!
  120. has anyone done an oil pan gasket on a supercoupe?
  121. Stupid Question (Jack Placement)
  122. 88 Thunderbird Problem.
  123. Antilock brake light and rock hard brake pedal
  124. 1993 Thunderbird, no tail, parking or dash lights
  125. eaton rebuild 90 tbird!
  126. Oil pressure
  127. '93 Thunderbird LX - Grinding Noise
  128. 92 T-Bird Blower problem
  129. 96 tach reading wrong
  130. 86tbird runs rough and shakes
  131. 95 4.6 cooling problem????
  132. 1982 Ford Thunderbird idle
  133. do you know where i can find headers at a good price for my supercoupe 1990
  134. Bolt Pattern and Spacing Question
  135. Ideas on how to patch ABS leak
  136. Improvements to be made to 429 Thunderjet???
  137. T-Bird Air Conditioning problems
  138. Crate Engine Recommendation
  139. 429 Thunderjet Question
  140. Newbie steering question
  141. replacing fenders whats the diff from CAPA and not
  142. 97 T-Bird wont perform
  143. Restoring a 1970 T-bird
  144. sponsors
  145. mph cut out
  146. Power Seat Failure
  147. Bad leds, cheapo fix?
  148. K&W block sealer after failed head swap
  149. 1995 tranny fluid
  150. 97 t-bird...TPS issues
  151. lookin for rear bumper
  152. AC problem, Actuator in Dash
  153. 97 T-bird trouble code
  154. 1994 3.8 T-Bird LX - Steering Rack removal?
  155. '93 Thunderbird fuel problem
  156. power problem in the t bird
  157. EEC-IV self-test connector on '93 T-Bird
  158. 1996 4.6L Running Too Lean
  159. 90 Center Console armrest
  160. question
  161. 97 T-Bird...idle issues
  162. Parking brake tbird -92 5.0
  163. 1988 Ford Thunderbird 5.0 v8, starts then shuts off
  164. 91 thunder chicken. car shaking.
  165. Brakes
  166. `95 thunderbird...need new lifters?
  167. tranny or bad ujoint?
  168. rear of car felt like
  169. egr
  170. thunderbird running problems
  171. fix up 97 thunderbird
  172. necesary?
  173. 97 t-bird can't pass DEQ!!
  174. obd2
  175. 89 thunderbird
  176. New Paint Color "HELP"
  177. transmission slipping???
  178. seafoam!!!
  179. autozone
  180. burning engine oil!
  181. Suspension Questions
  182. Help w/ 95' T-Bird power steering
  183. Another 97 Tbird problem- sunroof
  184. 91 tbird automatic seatbelt problems
  185. Electrical Problems EEC Fuse Blown
  186. funny problem with 1997 thunderbird
  187. 1996 Bird Trouble Starting
  188. '90 sc misfires
  189. 97 T-Bird, V-6 front end work
  190. 93 t-bird low rpm
  191. need pipes
  192. Who Would of thought.
  193. 96 no parking lights
  194. 93 bird 3.8L oil pump replacement issues
  195. 95 thunderbird customization
  196. Understanding my leak..
  197. 94 bird lx 3.8 starting probs
  198. will this help?
  199. 1992 T-Bird Trans Problem
  200. rear wheel bearings
  201. 90 thunder bird 5.0 NEED HELP PLEASE!!!
  202. best headers
  203. 55-57 thunderbird parts for sale
  204. 94 LX electrical problem
  205. 88 Thunderbird rear break pressure
  206. 1995 ford t bird check engine light
  207. i am not able to take it off of the park shift unless i disconnect battery
  208. 94 thunderbird radiator fan/ temp gauge problem
  209. exhaust system
  210. My new 5.0L Has,air,fuel,compression,but no spark!
  211. 1987 Thunderbird Heater Core & Blower Motor
  212. 87 thunderbird 3.8L V6 questions
  213. door panels
  214. 94 Thunderbird electric window problem on driver side
  215. 88 thunderbird dash
  216. mph
  217. '95 thunderbird running rough
  218. 90 T-bird tach install
  219. 94 Cougar question for owners of similar
  220. mounting motors
  221. 96 Cougar Quarter window
  222. A very lound noise
  223. brain burn?!!
  224. Spark Plug Change in 95 V8 4.6L bird
  225. body kit
  226. Exhaust
  227. thunder bird
  228. 90 SC Wiring diagram
  229. What engine oil to use on my -92 5.0?
  230. 94 tbird odometer
  231. Just bought a 94 T-Bird
  232. Timing
  233. Timing
  234. Anyone know how to keep from blowing heater cores?
  235. get her going past 2nd gear
  236. Sry mods for post repeat
  237. Foggy windshield
  238. 89 tbird sc question
  239. 95 ford tbird front brake problems
  240. Replacing tension strut bushings on a 94 T-bird
  241. 94 thunderbirds
  242. 95 ford tbird heater core replacement
  243. Need parts for 67 T-Bird
  244. Oil Pump Removal 1986 3.8L
  245. Parting out 88 Turbo Coupe
  246. Carbed 302 swap
  247. 95 T-bird Knock Sensor
  248. a/c and blinkers won't turn on/work
  249. 87 Turbo coupe wiring
  250. 87 Turbo coupe transmission
