Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Ford
> Thunderbird |
View Full Version :
Thunderbird
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
CCRM in a 96 TBird 4.6?
Pulley making squeaking/grinding sound
Thunderbird Idles fast all the time help!!!!!
Plug Wires
Rearview Mirror mount
Thermostat Options
Tranny is slipping with 80k miles on it...
engine swap
Valve Job Cost?
wipers stopped workin!!
Keyless Entry
Trans or motor mounts problem??
O/D light keeps blinking
thunderbird SC HELP ABS BRAKES
Headers for 1978
chip for a 88 tbird?
1990 sc THUNDERBIRD ABS ?????
94 t bird rim bolt pattern
94 ,4.6litre check engine lite on,need help!
1995 Tbird Won't Crank, Just Clicks
2006 Club Clash Dates Set - IOWA
Custom Seat Covers For A 90 Sc
Anyone Want My Dash?
Antifreeze Problem
88 tbird
T-Bird SC Odometer/Speedometer Gauge
Thunderbird Sc Motor Mounts
ford thunderbird
93 t-bird damage
1997 ford thunderbird
humming
instrument panel bulbs burnt out/dash disassembly
Help with Id-ing year of T-bird
Just don't know what it is.
fuel gauge problems in a 93 3.8
Thermostat is going waving up and down during warm-up
Tranny leak
r.i.p.
"Change Now" light stays on
90 T-bird Engine knock
car vibrates sometimes stalls
No Air Filter
AC pulley
spring compression
EGR Valve
IAC Location
Ordering spares online
97 bird window molding
starts but shuts off immediatly
More power for 95 3.8L
95 V8 Bird vs. 95 SC
289 hipo date code question
1990 super coupe smoking
New JET Chip for sale for 96 V8 TBirds
Replaced Heater Core... now wipers, headlight, heater not working
super 60 power?
I have had it
fuel pump switch
where is the iac
3.8 to 5.0 swap
hazzard lights on my 95
Lower Ball Joint
1972 Thunderbird
engine rebuild
rev surging problem
Time for a new engine?
Squeaking from rear.......
parts for the tbird
door panel
relay switch location
'90 tbird - break lights are out
Engine hesitating on acceleration
1987 turbo coupe i need help
v8 difference between mustang and tbird
1970 Dove-c heads on a 89 F-250 460?
Coming out of lock up
Oil type
after market stereo installation 88 t-bird
Overheating...
what next?!?
97 t-bird, burned it=
?s about civic intake tube mod
56 T-Bird value
Super Coup problems
92 Tbird Won't Start
advice needed
O2 sensor eliminators?
can i supercharg 5.0 thunderbird
95 T-Bird...Many Problems...Mostly Starting...
Number Matching Question
Dash Pad for 72 Thunderbird
What kind of lowering springs should i buy??
Need help finding where to buy sensor!!
front end knock
rear brake pads
1986t-bird help dont know what to do
1988 Thunderbird question PLEASE help
1983 Ford bronco ignition problem
Very bad Vibration Problems! Need Help fast!
Doors Frozen..
windshield washer fluid???
Fuel Pump Noise?
tbird damage right before the new year
Over Drive Question
need catalytic help!
info on bypass of hoses to stop leak of heater core into pass. compartment
determining if heater core is problem in '94 t-bird
coolant leak behind waterpump
compensator link
right corner taillight
'90 wont start when it rains
engine upgrade concerns
wiper switch for 1979 Thunderbird
Wiring diagram for a 1979 t-bird
shifting problem help!
hard start
Dash Cap
Car smells like eggs????????
need t-bird engine
interior noise
how to turn of check engine light
Transmission Swap
Heater Core on 1995 T-Bird
What's the best brand of Oxygen Sensors?
motor swap
'93 TBird wont start
1997 No start
86 Bird tranny ID and issues
air pump
instrument panel light change...
Engine Knocking
96 T-birds Check engine light chronic 4 years
94' thunderbird for sale
Running Ruff w/ C/E light.
97 thunderbird starter removal
4.6L Cracked Intake Manifold Repair
Timing Belt/Chain???
Can't Shift When Cold
shifter needed
Very rough idle
Bad gas
90' Tbird wont start.
instruction book
Traction?
crank no start
Part number question for 1972 Thunderbird
engine cuts out...
hard starting
on my way to work front right tire and suspension decided to stay behind!!!!!
Load humming noise.
Car won't keep running in park
HVAC control swap
Crisper Shifting in 95 V8
92 T-bird Transmission
1995 lx thundebird with v8 option
Quieter Power Steering Pump
electric cooling fan on my '93 3.8L?
fuel pump replacement
vibratation on bottom of car
Help with 86' Thunderbird
Popping Noise
Crank Specs
93 T-Bird Fog Lite Switch
Looking for a Supercharger
say no to rice and hello to beef
Heater Problem
Air Bag light blinks intermittently
97 tbird
new headlight lens lamps
Muffler suggestions - '92 Sport
1979 T-Bird (Smog Controls) North Carolina
1991 Ford Thunderbird Supercoupe for $675, good deal?
engine failure while driving(please help)
69 Thunderbird for sale
air compressor
new problem with 93 sc
Hey everyone!
88 tbird chip
front end shakes on 93
96 thunderbird 4.6L Ignition control module
66 T-Bird Loses Oil Pressure
1966 T-Bird No Heat
tire pressure on 91 ford t-bird 3.8l v6
problems starting the car
93 supercoupe aftermarket tach
stumped!! heat comes and goes
stereo problems in a 89
Cheaper Parts
after market intake on 88
fs 94 thunderbird in MI 1500.00
Heater Problem
Fuel Air Metering
New engine in classic tbird?
Miss my T Bird.
88 transmission
No Fast Idle
new intake on 93
Mark VIII Aluminum Driveshaft Upgrade
86 front bumper to an 88 front bumper
97 3.8L running lean.. help
turn signal hazard/flasher
Tail lens
no turn signals
87 tbird tc my engine wont start help?plz
motor trouble
92 sc thunderbird stops running then starts 20 min. later
cold air intake tube
checking fuel pump
vacuum leaks
97 Tbird dash light problem
vacuum diagrams
91 T-bird parts
Ever seen one of these?
94 t-bird wont idle
braking vibration, knocking after acceleration
302 into '88 T-bird
Parts for 72 Thunderbird
think i threw a rod....
Tranny
97 front wheel bearings
Bad Vibrations
95 hesitateing and vibarating at 30-40mph
HELP! 92-97 trunk lid tail lights out
water leak passinger side
Thunderbird Body Kit
1997 T-Bird battery light
1993 T-Bird Heater Switch/Blower Motor Problem?
remote starter
bad ball joints pics. heh
1972 Thunderbird wanted
94 t-bird tune up
88 thunderbird body kit??
1988 thunderbird navigation system???possible??
Dash light dont work!!!
Headlight lens replacement
'73 thunderbird brake booster
mustang gt 4.6 intake manifold on 95 cougar xr7
93 5.0 IAT sensor location
Terpsfan88
'93 Tbird wont start.
Will Bosche 02 sensor work fine?
3.8 to 4.6 plus T-45 tranny swap
Replacing automatic seat belts
85 Thunderbird power loss, Help!
rear bearings.
help me out guys
1992 T-Bird won't start
Need Help!!!!
new 94 thunderbird owner
93 super coupe power loss
Web
AF
