View Full Version : 5 Series
Pages :
[ 1]
2 3 4 5 6 7 8 9
- no paulse 528i
- Dead
- 540 1997 steering wheel shakes
- 86 535i Offset size for wheels
- Programming Key/Central Locking system
- 1986 535i cluster
- key and tyre loud sound
- Fuse Number for sunroof 1997 bmw 528i
- e39 oil consumption
- AC fuse keeps blowing
- Programming Keys
- engine runnig fast
- 530 v-8 to 540 v-8 swap
- 95 530i water in oil- no blown gaskit or cracks????
- idle adjustment 525d 2005
- Engine Vibration
- The Fuse box
- Bmw transfer case fluid
- 2004 5 series
- Code tester portal '04 530i
- 2004 BMW 530 i hood adjustment
- Mixed oil at change
- 89 535i engine swap now won't start...
- 97 528i won't idle, misses
- AC Schnitzer M5
- E39 BMW 525 TDS - Any Problems?
- Seeking X5 4.4 '04/'02 grey/black
- Replacing Rear speakers from a 2004 530i
- Drain battery if leave ignition key in?
- automatic transmission wont engage in 89 525i
- Need new rad for 1990 535i euro
- 01 530i Comments Please!
- oil service light reset
- door looked
- Light indicator doesn't lights up
- 97 bmw 528i battery light
- HELP!! 540i gauges stopped working
- BMW 5 Series blueprints
- 85 528E driver's bottom power seat
- 1998 BMW 523 fuel guage problem
- planning on buying 06 535i
- planning on buying a 06 535i
- 2000 5401a Complete Electrical Shut Down
- help-1995 bmw 525i
- Wiper spoiler attachment for 2003 530I????
- replacement key for 2001 530i
- bmw 530i stereo switching off
- Exterior temp reading
- bmw 5 phone cable red hot
- bmw cd
- Brand New '09 5-series
- 85 or 86 BMW Question
- Wiper Trouble
- 89-95 E34 bmw 5 Series must know facts before buying 1
- transmission fluid
- My twisted seats in my 1991 5 series BMW
- can i save my 525i
- 528i Radio dead, airbag indicator on
- 88 535i loud noise
- Rpm Decreases
- Replace Cassette Player 2003 520i
- 94 530i no power
- BMW 530 2001 activating wide screen TV while driving
- Tottaly confused! Please help
- BMW vs Ford
- I can't believe no one knows where...
- bleeding coolant system
- Strange noise
- Strange noise
- 1991 BMW 525i Electrical Problem
- BMW Recall
- i need opinons
- bmw525i doors do not lock right away
- Oil Filter location on 2004 530i
- Fluid levels
- 535-howling tranmision, is that normal?
- 535i-chugg, chugg, sputter
- help hunting idle when colg 525ia varnos
- E60 5 series bumper reflectors
- 88 528e - Clutch Fluid Reservoir - where is it?
- 1990 BMW 525i - Water Pump
- 87 525e problem with aerial
- 1999 525i wagon rear latch problem
- 2001 Bmw 530ia Advice
- 1988 535i RESTORATION
- Exterior Thermometer snafu
- e39 navi radio wiring
- 528it, 188,000 miles
- Faulty Light Indicator
- 1991 525i windows/sunroof will not work and the locks are all frozen
- boot lid problems
- intermittant hesitation when running
- 525 fuel prob
- bye bye ms bmw pie
- 98 Bmw 528i
- 528i intake
- 528e Starting issues
- 1997 528i BMW E39 2.8. Engine noise. Please help!!!
- 1995 bmw 525 I
- 325 engine or 525 engine..which one is it?
- 89 525i hesitation problems
- 95 525I- no power, strong sulfur smell
- bmw 525i 1995
- 1989 540 DSC light comes on while driving
- interior trim for 1997 e39
- How do I test my coolant for traces of Oil?
- 1995 BMW 525i
- used 94 530
- auto transmission problem
- hood opener
- Oil pan gasket replacement on 97 540iA
- erratic idle 87' 528
- BMW 1986e - Help!
- Wheels from a E39 on a E34???
- 1991 BMW 525i Radio says, "CODE".
- memory seat light stays on drains the battery help
- oil pressure light on at idle
- 1995 540i bmw
- 1998 523 E39 Electrical problems
- 1995 525i question
- BMW 535i wont start
- 04 530i trouble shifting
- 525i Central Locking issue
- '92 525i cuts out when hot
- Xenon light problem 540i
- Can't open the doors! BMW 535i, Help!
- Squealing NOise
- Windscreen sensor
- 83' 528e shaking in front end when turning
- Fastest speed?
- '95 535 won't start
- Corporate Fleet Lease
- 540i vs 525i
- clutch
- 89 525i m20 too lean,misses and stumbles in idle & drive
- headlight chime/warning
- 1988 528E O2 indicator light won't turn off
- Tie rod problem
- 1999 540 water temp sender location?????
- 1998 BMW 528i
- Maintenance Advice
- engine knock when running m20 90 525i
- m20 oil pan removal
- 97 528i abs problems
- no start
- no start
- Need help gages bottm out
- Which oxygen sensor is bad?
- 2004 545 rattle in sunroof
- 525i and 525ia
- Hey guys/gals! I'm new to the forum and
- Cylinder liners
- Running problem on E39 1997 97K
- 90 525i engine knock
- 90 525 fuel pump?
- 89 525i radiator
- Will a 525i engine fit into a 325i body??
- Id like to know if I have sports suspension
- 530i help
- completely dead
- nobody reads these so why post
- 98 528i overheating, thermostat?
- 90 bmw o2 sensor 525i
- 85 BMW 535i help replacing ignition swith
- 2003 525i Heater and AC Fan not workin
- Help Please?
- e39 sun roof won't tilt up.
- 528 with its own mind
- Ambient temp probe location 2000 528i
- E39 Multi Electrical issues
- 528i front cup holder
- 1999 528 Unlock Problem
- Synthetic Oil
- LKM (LCM) problem '01 525i
- Options: Battery Switch
- Possible head gasket failure.
- Secondary air system
- 99 528it vs 00 540it
- 2004 545i active steering malfunction
- 1990 535i: Which Oil? 10W-40 or 15W-50
- by passing the stock amp on 1998 528i
- M50TU Differences
- k n filter/induction kit e39 540i. Any opinions?
- Replacing bmw cd player stereo with new mp3 player
- 94 525i
- Suspension query on auto e39 540i. Auto have sport?
- 540i vs 740i. Manual vs Automatic..?
- please bmw 525i owners handbook
- 1990 bmw 525 dim lighting problem
- stock radio replaement on 1998 528I tape/radio
- Heater Core
- Buying a 1989 BMW 525i
- e39 Navagation System
- recharging my 528e ac
- 2003 530i
- Is my frame bent?
- 1990 535i: Transmission does not reverse!
- Interior fan
- 89 525i - Electrical Prob.-Windows,Wiper,Sunroof
- E39 Engine warning light
- 1998 528i Overheating
- Hazard switch always on
- E34 interior switch
- how to replace switches bulbs
- 2007 J.D. Powers Initial Quality Study...BMW Declines!
- E34 535i Auto
- 92 525I to 95 525I w/VANOS???- HELP!
- 2004 525i coolant replacement
- e28 tuners and engine swaps
- 525i
- my e28
- BMW 2003 525i - Possible to add factory GPS?
- 05 530xi nav/idrive problem/question
- A keeper or not??
- Just got a 1990 535i and problems...
- Metric temperature display
- this is a weird one
- 90 bmw 525 runs sluggish
- HELP! Who knows about LKM's?
- 535I tires???
- E39 With intermittant engine power loss
- 07 I drive full screen (NEW)
- Bmw 520,525 wiper problem !
- BMW 99 528i sounds like a turbo prop plane
- Speedometer Readings?
- stripped lug
- 1999 528i... no start... keeps blowing fuse...
- 1998 528i overheating
- getting power to new GPS
- starts and dies
- 99 e 39 no spark
- 520SE Noisy accelerating
- 525i vs 528i
- F/S 97 540i, 11,000 obo
- '88 528e broken cable and flapping/knocking noise?
- 1984 533I Speedo
- E39 - '97 528i 5spd. Supercharge it?
- looking to buy an e34
- bmw 1993 diesel automatic
- Please Help Fast... Starting Problem
- spark plugs
- 07 530 xi
- 1984 528e back windshield--compatible with others?
- 90 525 Rear Brake Repair Help
- Wheel size
- Radio CODE Retrieval
- ENGINE KNOCK 1990 525i m20
- cylinder 5 not getting fuel causing knock
