View Full Version : 3 Series
- '97 318i won't pass ILL emissions test
- change E36 convertible top to an E46 top
- replacing ignition coils
- Head gasket or jamed thermostat
- Turn Signal Indicator
- Fuel Level Sending Unit
- Instrument Cluster Wire
- Z3 Engine
- premium or not
- 2004 330Ci low speed hum when stopping/turning
- Tons of BMW DIYs
- carbon fiber and fiber glass kit
- Looking For Wheels For your BMW 3 SERIES??
- Antenna swap on 1999 323
- 328i 1996 convertible
- 99 E36 Cabrio Climate Control now Dark
- '77 320i=$2000?
- Reference Sensor on E30
- 1993 325i - good reliable car?
- Hardtop Conversion Kit
- 1988 e30 325i? LSD or not?
- '86 e30 s-charger or turbo?
- Looking For a Good LA repair shop
- 23,700km - 14,500miles: 1st oil change
- Getting a BMW
- Headlight Leveling
- clear corner lights
- 1984 318I Problem
- door locks
- Window Problem on E36 Coupe
- BME ser. 320i-model 1994
- 325is window problem
- Decoding The V.I.N.
- 318is flat spot problem please HELP
- 1986 325es
- 89 325i
- alarm problem.
- 2001 330XI possible 1st owner
- Transmission failure on 2000 323ci
- 2001 325i control arm replacement
- BMW unveils new biturbo straight 6
- 95 325i wont start
- Increase MPG
- installing a perfomance chip
- 318 that vibrates/shakes
- New BMW Owner
- unbeliveable!!! read on
- rear suspensio noise need help
- restore engine product
- vanos noise
- Outside Temperture Sensor Location
- New BMW Portal FYI
- 89- 325e timing belt
- buying perfomance chip on ebay
- BMW E36 318i ELECTRIC WINDOWS PROBLEM
- Drivers door won' t open, HELP!
- bmw; park distance control
- 1999 323i sunroof
- doors won't unlock 97 328i
- 86 325e door
- 2005 convertible
- Best BMW 3 series Extended Warranty?
- 2000 323i OEM audio parts
- Look
- 95 316i problem
- Help with mY alTernatOR!!!! PLS!!!!
- EWS III problem - no dealer access
- 1993 325 is computer reads in German.
- 1984 318 Bauer Cabriolet
- Complete electrical failure?
- Oil Change
- Electric Windows - ANOTHER PROBLEM
- E36 - PROBLEM, please help!
- E36 Convertible Power Windows
- upgrade prefomance ignitiion coil and chip
- 320 td e46 non start
- Good Exhaust System?
- Angel Eyes
- 1995 320 i, RUNS ROUGH AFTER 2 MIN
- alarm
- High RPM's
- Central Locking
- Instrument Cluster Troubleshooting
- Timing belt?
- perfomance chip question
- Where can I buy a Sunroof?
- 325 motor swap or rebuild?
- '88 325 glove box will not unlatch.
- BMW auto colling during high heat when off?
- bmw 330i v tl
- Blow-by
- 1986 325e
- E46 remap
- Weight of 325es???
- 1999 323i Drive Shaft
- Modifications
- supercharge or turbo
- 2002 318i - mileage too high?
- Advice about DSC in my 01 330CI
- Starting problem
- Mystery Plug
- ATF lifetime
- wide bodykit
- Anyone have 1992 325i, I have a question?
- help buying 328i 2000
- High idle speed
- 1999 323i
- sport and premium packages includes???
- 318i Buy or Not
- klunking type noise on my rear pasenger wheel
- Location of EWS II control module
- I replaced the ATF on my transmission, and now it's stuck on D/drive
- automatic transmission will not shift after ATF change
- EWS module faulty? Key reprogram?
- 1993 325i Huge Problem
- Starter Relay Position
- (dumb question) where is the gas tank switch?
- No Battery Voltage to Starter
- Bluetooth Sync
- Sirius Satellite Receiver
- Paint
- 1992 318i
- replacing oil filter canister
- heater core on a '91 318IS
- directional light not working from time to time
- 2002 BMW 330xi
- Convertible Top
- Cooling system bmw 323i
- will not start
- Backup Light Switch - 1980 320i
- Help please
- code problems!HELP!!!!
- Driver 's door key lock problem
- No radio manual need help
- under carriage problem
- Missing Floor Heat 1995 318i
- Engine Will Not Start....can anyone diagnose this problem??
- 95 325i finding dtc's??
- stupid problems
- e-30 doors
- e 30 rims
- Trouble code 215
- 94 325 Maf
- what should my first engine upgrade be
- Replacement bulbs for e36
- when it's cold outside car will not start!
- 1987 325i brakelight problems
- Do I Need to Replace DME Chip ??
- Need some info
- Drivers door window problem.
- OBC upgrade
- grumpy and lumpy e46
- Question: Buying 93 325i
- fuse box
- 318i no spark cylinder #2 - Need HELP !!
- Older or newer?
- Crankshaft Sensor Code/Engine Didn't Start
- reverse lights problems
- 330ci alarm question
- Viper Alarm/remote Start Problem
- rpm geauge and gas economy geauge
- idling probleme
- installing a headunit in a 1989-91 325i! need help now
- Need a SouthEastern navigation cd/dvd
- unstable idle speed
- Oil question.
- e46 330d brochure
- oil bolt`s location?
- oil type for 2000 323i
- 2000 BMW 323i cd player
- Paint code for Gray Skirting
- Help finding Airflow meter
- 2002 325i
- 2000 323i for sale
- Weird Sound on my 2000 323i
- 88 320i needs some help.
- spark plug location?
- Help me start my car
- shaft that connects ignition switch to ignition tumbler
- 1993 325ic steering rack help R&R
- 95' 325I Check control display
- 1985 BMW 325E....Radio Codes
- 1985 BMW325E Trunk won't open
- Need advice about 96'328i coupe ECU
- Steering wheel lock/Ignition switch/Car start problem 1983 320i
- Problems with new 95 325i
- question about interior colors
- Looking for a sideskirt (Right Side)
- Hazard lamps will not turn off
- Resetting the SRS warning lamp
- blower replacement
- 2000 BMW 323i
- Can blown muffler damage engine ??
- Celcius /farenheit on AC display
- Stalling
- Soon to purchase 330ci
- backup light problem
- Dummy Lights will not go off, ETC!!!!
- 1996 318i final stage unit
- High milage 325IX ???
- no heat blower temperature gauge
- After Market ECU for Turbo Kit?
- 1999 323i Thermostat swap
- 1994 325is
- Camry warning light
- Help whats that noise
- 318i dashboard layout
- horse power
- Rat-rod
- ignition lock cylinder/switch problem
- Windsheild wiper motor replacement
- Hood latch stuck!!
- fouled spark plugs
- Clear Indicators
- About mpg on a 320i
- Parts Wanted
- Window Replacement
- Thinking of buying an '01 325i
- 1991 e36 318i (m40 engine) air temp. sensor location
- 320i e36 ignition issue
- New Member: Digital Climate Control Query
- 2001 bmw 320i
- blower motor chatters
- CD storage sleeve - airbag hazard?
- 1995 318i Door Locks, Fan Motor
- 318i 1984 quite a few problems
- 2001 318i emissions light on/off on/off
- Psycho dude goes to ex's house..
- Convertible top Care questions
- Oil in spark plugs
- Slow to Start - Gas Smell
- 93 325i E36 fan clutch removal
- Broken into Bimmer
- Factory Alarm
- My 318 Ti!
- 323i Temp gauge?????HELP!!!!
- 93' 325is Seats... Will 2000 323i seats fit?
- 318i Heater problem
- BMW 316ti
- 1989 318i Clutch Problems
- have you seen this new e30 site
- E46 Climat Control
- BMW E46 328, Engine Mangement Light
- Nokya H7 Arctic white Bulbs
- Trans Program Problems
- E21 idle speed
- 86 325e
- Creaking latch: fold-down seats E46
- 323i door palaver
