View Full Version : 900
- 1997 900S Displays Temp 30F
- 89 Turbo - Need Engine Pictures
- Anti-Lock Brakes, Sport & Winter Mode, Heated Mirrors, etc.
- Sticking Gear Shifter
- 900 Turbo Wheel Hub
- Hot seat during winter
- 89 Saab 4-door Turbo-Check Engine Light
- 96 Saab 900s Head gasket, can a leaking head gasket cause a starting problem?
- Where is windshield water pump located?
- exhaust system
- 98 Saab 900 SE no spark
- 89 Saab 900, How to change belts.
- 97 saab se , cant get conv. top to latch
- Noise from front end
- common problems with these cars?
- I have a 94 Saab Turbo Convertible, need an alternator
- Mysterious Belt
- Mitchell on Demand Service Manual
- possible tranny problem
- 900 se V6
- Anyone have some specs??????
- 95, 900s, 5speed,runs but wont go into gear....
- Radio manual tuning function?
- 900 Parts - to fix, or not to fix...
- 97 900S Oil light question
- 86 Sabb 900 MAF problem...
- 1995 SRS light ON
- saab story
- 1996 SAAB 900 Alarm
- Starter Problem
- 1996 Saab 900 code P0410?
- Transmission Pops out of 4 and 5 gear
- Cold Engine stalls when put in gear
- Are the headlights automatic?
- 94 900: need sideview mirrors! radio advice?
- Service Manual Anyone?
- timing belt blew 94 2.5 v6 any point in looking inside?
- Vanishing Instrumentation!
- Problem with tail lights and related wiring
- Electronic Heater Control
- Engine dies but eventually starts back up
- Waste Gate selinoid??
- Door Lock Problem
- saab 900 v6 doors wont unlock ?
- Tires/Gears Locked?
- 1959 Alfa Romeo Giulietta Spider Veloce Pricing Help
- 1993, 900 low battery stops car
- how do i change the starter
- 89 Saab 900 Clutch job
- what is the average mpg for a 900 turbo?
- 1994 Saab Se 2.5 Fuel Pump Relay
- fuel system 94 saab 900 2.5
- My 900s shakes in idle and reverse
- '97 900 hatchback good buy?
- 94 900se flasher
- 1994 Saab 900s transmission?
- 1994 Saab 900s oil light question
- 89 900 Turbo Convertible - Good car to buy?
- 900 clutch life and trans fluid?
- Volvo intercooler on a Classic 900?
- SAAB 900: Good car?
- 97-900 Headlight clips
- 94 Saab 900S V6 problem
- SAAB 900 SE electrical problem
- random question
- alternator belt went while driving
- 900 S warm starting problem
- 90 900 turbo no start
- 1996 Saab 900SE tonneau cover
- 1996 saab 900 se turbo radiator
- Saab Repair Manuals
- help
- 96 900 SE Turbo Lights Queston
- Need Headlights!
- Check Engine Light
- Saab Wheels
- '88 900 Clutch Replacement Procedure?
- 900S Bogging out
- 1992 Saab 900S Overheat?
- Amplifier Bypass
- distributor
- convertible top doesn't work
- No shifting
- 1988 Saab 900s Turbo
- For Sale: 16" viking rims
- Will Not Idle
- head gasket
- interior lighting
- Quick taillight question??
- Locked out by anti-theft deadlock
- Ignition diagnosis help please
- 1994 Fog light bulbs
- 1992 saab 900 abs brakes
- 97 saab 900 questions
- Dash lights
- saab 900 se turbo-newb question
- 1996 saab 900 se turbo ---srs light---
- Slow to Start ... Fuel Pressure Regulator?
- 96 saab 900se turbo--SRS light on----
- 1986 saab 900
- 82 900 turbo ignition problem
- timing help 95 900se
- 96 saab 900se turbo--Tachometer and fuel gauge problem
- 1996 saab 900 clutch replacement
- 1995 Saab Turbo Issues....Suggestions please
- Overheat
- Wastegate PSI
- shifter knob "inset" piece?
- Head unit gone bad???
- Turbo Conversion
- getting started...
- replacing clutch on 900SE
- Stealth FX
- 97 Saab 900 Blower
- value of '91 900 S ex-trans
- wastegate vacuum help
- turbo help
- classic 900 spark/distributor issue
- SAAB NG900 Convertable, 1996
- windshield washer fluid
- coolant leaking onto driver's side floor
- The gremlins have settled into my electrical system!
- idler pulley
- Is this Forum Dead or Alive?
- Transmission Issues (5spd )... Here we go...
- Value of a Saab 900SPG -1985 pearlwhite.
- BG syncroshift For your 5spd
- Saab Body kits
- Saab overheating
- Sabb - 1997 -900S @ 89k $4,100
- NG model Shift Knobs???
- Shadetree mechanics pls advise: transmission/clutch
- What does Scania mean?
- 1990 900 S slow starting
- 86 900 SPG/Aero Wheels
- Saab Servicing Queries !!!
- Saab Body parts
- What are 900 NG models?
- 900 turbo specs?
- Saab parts
- c900 Carbon Fiber Hood
- 1996 900 won't start
- 900 turbo convertible front seat head rests
- Saab 900 remote?
- keyless remote entry programming
- Major question regarding performance
- Direction Indicator arm
- Squeeling in First 3 Gears
- water pump
- 97 Saab 900 S Hatchback
- Saab 900sx
- Intercooler wanted!
- Value of a Saab?
- The "Silver Bullet" Rides again!
Automotive Network, Inc., Copyright ©2012
