Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Nissan
> Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
View Full Version :
Pages :
1
2
3
Pulsar Problems
2007 Versa radiator drain
tino immobiliser
what eng can i put in a 1987 pulsar
2008 Versa front brakes
Quick warranty question.
The nissan sentra coupe or other wise known as the sunny zx coupe in other parts of the world
Shift Lock
series 2 bluebird, Im after the fuel consumption at idle
Servicing the CVT on 2010 versa
Nissan almera alarm (nats)
A/c blowing hot air
upholstery question
91 nissan stanza electrical problem
Service Egine Soon
Question about Nissan Almera 1.5 2004 versions
Sportbak for sale
ga15 jdm engine a/c idle up
92 nissan NX headlight and dash lights no work
Positive Crankcase Ventilation (PCV) that '92
My Stanza Jumped Into Neutral on the HWY and won't go into gear.
2009 Nissan Versa beeping when shut off
Versa AC cuts out
'85 bluebird ca20 twin spark alternator prob
09 Base Versa w/NO A/C
Cam / Valve Timing for Nissan GA15 engine
08 Versa stereo install
NX 1600 Gauges going BONKERS y'all! ECBM ?
Convertion kit for Nissan Almera
Throw out bearing?
90 stanza fast idle problem
avenir swap into bluebird u12 speedo n rpm doesn't working @@ HELP!!
Engine rattling and loosing power
Nitrogen filled tires... is it worth the money?
Sunny dashboard light
Nissan Relay Problem
Oxygen Sensor
92 Stanza-very hard to start when cold
ABS brakes on an NX1600
HELP with N16 Pulsar Service Manual
2004 1.8i P1122 & P1126 fault codes
almera gps update
Power window regulators
Ignition key chip disable
1988 Stanza
1995 Nissan Bluebird Stereo Installation - HELP!!
Sunny 2000 - engine shuts off when idling
HELP: Installed battery on backwards
Nissan Almera Radiator Fan Not Turning On
nissan almera petrol 1495cc 1996
nx 100 water leak
Alarm scam from dealer: Is this normal?
Automatic Trans switch
rad
Ka24E OR Ka2DE
1985 Nissan Bluebird Car Stereo Wiring
2002Almera 1.5 Oil problem with spark plugs
transmission oil how much
pulsar fitting drive axels problems
93 nissan nx owner needs help
87 Stanza sedan for sale/part out-170k
found a 1987 NISSAN PULSAR w/as a beater car-need some opinions
88 SE CA18DE CODE 11 Crank angle sensor
Need Windshield Help!!!!
wiring help?
My stanza wont start :(
Nissan N16 L Series
Fuel Consumption
stanza
timimg belt diagram needed
body kit and engine for almera sport please
91 stanza tranny problem
Pulsar Headlight problem
almera 1.5/ on y plate
1998 nissan almera phase 2 body parts!!!!!
2001 nissan pulsar *IDLING* Please HELP me
Stanza timing chain kit cheap!
91 stanza overheating
Power steering on almera P reg?
Bluebird Auto Gear Change Probs?????
Almeria Tino Electri windows and sunroff problem
Stanza racing helppppppppp
Engine Cuts out after 5 minutes!
HELP PLEASE NISSAN AVenir
Gas Consumption Not What I expected
nx 2000 sr20det
Wanted: Sunny Zx body kit
Almera idling
Selling my nissan pulsar vector
tranny info
Fuel Pump Connections
Nissan Almera Standard Radio Removal
stanza engine problem?
90 Stanza For Sale
Nissan Almera Active 2001 1495cc upgrade
have pulsar parts car
I'm Broke
I need a steering wheel for 1992 stanza
93 nx 2000
engine overhaul
engine wiring harness
ARX and none arx rear bumpers the same?
central locking probs
Nissan Sunny Exsalon 2001 Help
1991 stanza fuel pump
Ca18det for sale
Almera GTI performance
sr20
Detonation Error
Please help a knucklehead find the starter!
Need Cam Sensor for 88 CA18DE
Non-stop '88 pulsar nx se problems..HELP!!
Gearbox Problems Or Is It Something Else?
1.6 timing
Flashing lights - keyless lock
Advice on buying '85 Pulsar
Nissan Speed Sensor
VSS (Vehicle Speed Sensor)
1992 Nissan NX 2000 engine needed, what fits?
Looking for elder wisdom and/or peer input
89 pulsar 1.8L ran outta gas, now doesnt run. help?
Lost key
cv boot replacement
Looking for replacement parts online for NX2000
1992 Stanza Engine Problem
erratic spedo and overdrive shift
sunny ingine
parts that i do not know where they go!!!!
erratic speedometer 1990 nissan stanza
92 NX1600-need your opinions
need aftermarket parts for '92 stanza
Almera Tino Headlight Deflectors
LOL, interior trim problems!!!
b-14 se-r tranny swap auto to manual
Instrument Panel and Shifter Won't Light
WTB: Nissan Pulsar Sportbak (with or without the car!)
More idle problems
91 Stanza speedometer cable location
nissan almera tino, starting problems after leaving idle for about 2 hrs
Almera 1.8 Sport Plus.
Loud Clicking from Steering Column
92 Stanza CD Player Upgrade
Recommended type of tranny fluid
Looking 4 Swap Opinions
nissan brake problem
89 Stanza auto trans/speedo problems
Japanese translation for Navigation Console
N15 in Sydney...
Bluebird transmission noise?
Bluebird (U12) centeral locking
87 stanza fuel pump
87 stanza fuel pump
unsure so im asking you guys
Stanza 1992 Oil Leak
90 Stanza XE fuel pump fuse keeps burning out (popping)
89 pulsar nx wheel bearing
87 pulsar question, E-brake..;-)
Rally Stanza
87 Pulsar, 2 questions
timing belt replacement interval for 88 Stanza Wagon?
Melbourne
!!!!!!!wahooooooo coil overs for 87- 89 an 90-92 stanzas
88 pulsar question
Nissan sunny central locking
nissan pulsar roadtest
5th gear popout fix
Help please
link kit
Idle Problems
1994 sunny inspiration clutch
Timing on '87 Ca20 Stanza
1992 stanza xe looking for parts...
90 Stanza Idle issues/bucking
I just bought a 92 nissan stanza
1991 stanza wont start in cold
Shifter Linkage? 1988
87 Pulsar NX clutch problem?
How do I change the starter on an 88 stanza.
Engine conversion
91 Stanza trunk lock
1987 Nissan Stanza - Starting/Dying
Air filter upgrades for Almera
got issues
1992 Stanza: won't start in the cold
1998 Bluebird SSS information needed
84 stanza wont start.... help!!!!
Nissan Sunny L (pulsar shape)
87 Stanza starting problem
Nissan Avenir Salut X 1996 manual wagon - a good buy?
Wingroad 2000 wagon - a good buy?
Help!!!
Nissan Sunny (Sentra) B14 non-obd ECU
Nissan diff /ATS , who knows??
Repair Advice - Dashboard Lights
What IS the ECM?
fuel/brake/amp light on non-stop
1992 4Dr stanza
SR20VET question
Paint/Graphics on a Stanza?
No Starty
1992 stanza (1) cyl no compression
89 Pulsar NX engine
Pulsar NX SE with bad motor - CA18DE?
ca20 4 plugs working
Stock 9-Spoke Alloys Wanted
KA24E help
Do anyone have E16 Torque or Power curve???
Looking for some parts...
1991 N13 gauges problem
1990 Stanza factory service manual for sale
Exhaust Bluebird 76-9/77
Looking to swap or Turbo my 91 SE-R
almera hiccups coasting in 4th/5th gear?
Importing.
87 nissan pulsar SPORTBAK for sale
nx VIN help
Pulsar Q engine Swapping
Bluebird and SSS Bagdes Needed!!!
Newbie saying hello...
Nissan Almeria Tino
Stanza Owners
sunny to nx
getting the ca16 engine to start..
nx engine swap
90 Stanza won't start
Stanza Vacuum Hoses
Dim Headlights
85 Stereo Wiring
mid-engine shoe box
ca16de ignition module
1988 nissian stanza
Some big news for me
tonnes of et parts for sale including!!!!!!
Timing Digram GA15 pulsar
Nissan Pulsar 91 GA15
engine conversion
gtir
ca16de coil-on-plug ignition
I need a lot of help and fast for whoever may help me....
car comparsion question
Nissan almera immobiliser
Parting out 88 pulsar sohc
U12 Bluebird
Almera Lights connections
1987 nissan stanza wagon 4WD
N13 Pulsar Fan Relay Problems ..pleeasssee Help!!!
crank bolt on a ca20
engine swap
1988 Nissan Stanza
Automotive Network, Inc., Copyright ©2012
