- Front Right squeals in reverse
- Clunking in rear
- 4 cyl performance for cheap
- Fuel Sending Unit- PO463
- Propeller shaft - too much grease?
- lube question
- Xterra/frontier S/c 3.3 Injectors?
- 2005 Xterra Noise & Shifting Probs...
- 2000 Xterra Automatic Transmission Questions
- Tranny Overhaul
- Frontier Help.
- 2001 motor mounts
- 4wd conversion
- specs for 2k spindles....
- cap distributor....
- tool for differential plug?
- Transmission delays
- clunck noise
- 05 xterrs se 58k clicking from front
- Noise when Clutching
- U Joints
- 03 xterra noice when in gear
- I think I killed my XTerra ... please help
- 2000 X slow shifting
- 2007 Xterra - less horsepower and torque
- Ticking sound after sustained driving
- grinding when shifting
- Calamini Exhaust? Good? Bad?
- Intakes - Affordable that work?
- 2005 Xterra SE Rear Differential
- 2000 Xterra 1st Gear Stopped Working
- Basic Power Mods
- looking to put larger engine in my xterra
- AC/4x4parts T-case gears available!
- Short Shifter??
- Front End Clunking
- Gas tank overfilled. Will this create problem?
- Please help, I put diesel in my xterra
- Strange noise on accelleration
- Gas mileage
- I need Help! A loud nois
- How many channels does the ABS have
- looking to lift 03 xterra
- Aftermarket Cams experience?
- ABS Light On
- xterra rear axle
- Shuddering at idle
- we cant find the heat
- overdrive ?
- Stupid Nissan
- POwer Loss!
- 2005 performance items
- questions about lockers...
- Tranny problems (?)
- hard shifting auto tranny
- The Air Locker Installation
- Drivetrain Mileage?
- Xterra differentials compatible?
- Locking Differentials?
- E brake not holding
- Delay shifting into drive
- Coolant Leak/It Just Popped out!!!
- Problems
- PCV Valve
- clutch/tranny problems???
- anyone have pics of x with 31 and or 32 with stock lift
- Slight Vibration
- 70's beetle sound coming from engin area
- Clunking sound when changing into reverse.
- how much would it cost to have the timing belt changed
- any change fluid in transfer case
- which gear oil to use for differential
- SuperCharger Gas Premium or Regular
- Rear Brakes Overadjusting Themselves
- how hard is it to make an n/a x a supercharged x with factory supercharger
- tranny problem????
- Locker preference?
- Bad Vibration
- Shuddering below 2000rpms & grinding noise during start
- cLUNKING nOISES
- Vibration in Drive and Reverse
- Strokes at idle and slow speeds
- Ses
- Anyone have success installing a supercharger?
- 2005 Xterra, Any Problems?
- auto hub:manual hub, difference?
- Vibration at idle in drive & rear seal leak
- Turbonator or Super Charger?
- High pitched whine from engine area
- Service Engine soon
- Cold Air Intake
- Aftermarket Supercharger Kit Available For X
- Clutch or Throw Out Bearing?
- intake
- Aftermarket Exhaust for 2003 XE
- How to defeat speed limiter?
- reverse
- spark plugs and battery
- transmission filter
- troublesome transfer case
- Tranmission Cooler & Filter Installation
- hubs won't lock
- clutch groaning
- Performance mods
- 2000 Nissan Xterra
- Clutch mushy on cold mornings
- burnt smell in x sometimes??
- engine problems
- REd Line Oil & Gas Treatment
- Flowmaster on X
- new to this
- should i buy it
- Vibration
- Xtera Lifters
- noisy torque converter
- auto hubs
- lifting my xterra
- Headgasket Leak
- Rear end Whine
- Front Oil Leak
- newbie shift question
- vibrating gas pedal
- Serial number of engine
- Great air intake for less than $150
- Cruise control just stopped working
- 2000 XTerra Thermostat
- need a steering upgrade
- upgrades and mods
- Jumpy Tranny
- Air Filter Cleaning
- Limited 'slippery' rear differential!!!!
- Trouble codes
- Any tips on PCV valve removal??
- front axle, 4x4
- Spark plug No.4 slapped in half
- Alignment
- xterra engine questions?
- low fuel
- Ring and Pinion
- altinator
- Brake problems...
- 2.4L altima ?_sorry yall
- intake sensor upgrade
- 4Hi to 4Lo
- Is this Crap or Good??
- gibson duel exhaust?
- Rattle Coming from the front
- lsd rear end
- 3.3 s/c Mods...looking at a Frontier
- What parts are better for me to get?
- Pathfinder Engine in Xterra
- Exhaust system
- Dynamic Control Package question
- What are the difference between the SC VG33 motor and the VG33 NA motor?
- Whining noise in 4wd LO
- Auto lock hub acting up?
- Clicking noise when driving and i must put x in 4wd to stop it
- A/T Fluid Capacity
- Tornado Gas Saver
- Starting problems
- timing belt
- Gibson Cat-Back for a S/C Xterra
- powertrax no-slipfor chevy wagon?
- Best Exhaust for the $$$
- rattling noise when accelerating
- S/C Stainless Cat Back Exhaust
- Free Replacement Of Manifold
- shifting from 4lo to 4hi
- do all 2002 xterra se's have limited slip?
- Direct Power System = crap?
- Nissan Sport Muffler?
- knock sensor and P1148 errors HELP
- Wishing I had overdrive...
- Clicking (relay) noise in automatic console
- 10 more horses for 03?
- 2003 Upgraded Alternator
- Spensor Low Headers
- Calmini Hi-Flow Exhaust
- Rockcrawler tcase install
- Adding A Supercharger
- 4cyl Performance Mods
- Perfect Power
- 4Hi Shift speed
- Supergharge?
- Timing Belt?
- Exhaust Rust/Replacement
- Pics of the R200A
- Driveshaft Replacement
- 2003 xterra titanium dash trim
- Engine Modifications
- *Lots* of front brake dust...
- Braking in Rain
- Which year XTerra has lockers.
- 2000 Nissan Xterra Exhaust Manifold Crack
- Fuel gauge will not read full.
- 87 300zx turbo r200 lsd to 95 r200a swap
- Towing limits manual vs. automatic trans
- T-Case Gears vs Air Locker
- K&N Aircharger
- Mods that wont void Warranty
- Gear Ratio's
- Has anyone used Airaid and/or Poweraid products on the X?
- catback exhaust
- spark knock
- Detriot Electrac
- Quick question.
- lsd last question didn't get answered!!
- Pop-Charger and Performance Exhaust
- Poping sound from rear end
- accelorator pedal sticking
- Fuel Sending Unit Problem???
- Ticking Noise When Cold???
- What are the pros and cons of the manual and the automatic transmition?
- LSD oil only sticker?
- New LSD options!
- Help?
- New custom rear springs available at AOR
- Noob looking to buy Xterra
- SLR Headers Released
- whinning noise while in 4wd hi
- stroking a pony
- grinding/clicking noise in hub
- Manual hub troub....(Warn)
- changed Manual Transmission fluid
- Transmission question...
- Lsd
- ARB Air Locker
- Unlocking Hubs
- has anyone replaced the bolts on warn manual hubs.
- Question about driving without front diff
- Cheapest place for a half-shaft
- Problems with K&N Aircharger
- 4 wheel lockup
- cornering in 4W High
- Diff & T-case fluid
- New Toy
- to many rpms
- Powertrax Lock Right Diff. Unit
- Oil Leak- can we identify cause?
- Jim Wolfe Technologies Pop Charger
- Supercharger
- Axle assemblies
- Front Vs. Rear Locker Test
- Ordered Engine Upgrades
- Add me to the "cracked manifold" list.
- Warn Manual Hubs
- Xterra Lockers
- Gearbox problem?
- Speed Bleeder installed too!
- Gibson exhaust installed.
