View Full Version : General discussions
Pages : [1] 2 3 4 5
  1. engine swap
  2. problem with A/C
  3. Xterra 2005 reverse problem
  4. Manual vs auto
  5. xterra burning oil
  6. True or Catback Dual Exhaust System
  7. My 2002 Xterra...a few simple questions
  8. P0420 Code on Xterra
  9. Locking Steering Column 1996 Sentra
  10. Thinking of purchasing a 00-02 Xterra
  11. lifters not fast enought for start up ??!!
  12. High Pitched Noise Upon Acceleration
  13. Power windows problem
  14. Oil in the radiator and in the radiator fluid reserve tank
  15. Need used or really cheap fender
  16. OBD problems
  17. Are my hubs the problem???
  18. GPAX Meet and Greet - PA NJ NY DE MD
  19. 02 Angel Eye Conversion HELP
  20. I need info re:2005+ xterras! what falls apart first?
  21. Lower gas mileage
  22. Startup rpm ?
  23. Sparkplugs
  24. Xterra Power steering issue
  25. cracked intake manifold?
  26. MAF sensor
  27. 2000 X Terra ABS problems
  28. To good to be true?
  29. New Xterra - preventative maintenance
  30. '00 or '04
  31. Lift kit question?
  32. how much should this cost?
  33. locking doors
  34. How to you remove the rear strut springs?
  35. miles per gallon
  36. Hauling extra fuel and tires for long trip
  37. "New" '01 X. Mods for Baja trip?
  38. Just Stopped Running
  39. 2000 Xterra - lighter won't work
  40. One headlight is dimmer than another
  41. Replacing Fluids
  42. High idle problem.
  43. 2006 tire wear
  44. knock sensor problems
  45. 2007 Nissan Xterra- 3000 miles
  46. 2007 Nissan Xterra- 3000 miles
  47. Weird metal vibrating sound?!?!?!?
  48. bright white bulbs
  49. Spark plug gap for 3.3?
  50. Is this a good price?
  51. Timing Chain
  52. 01 Xterra Mod Questions
  53. 2001 Xterra with rough when first taking off
  54. Replacing O2 Sensors?
  55. Service Plan? (and way more)
  56. Poll: Owning A Xterra
  57. Crossbar suggestions for toting surfboards..
  58. PIAA 520 Driving Lights
  59. Northern Winter doorhandle problems???
  60. special steps/tool for torqueing spindle nuts?
  61. After Market Xterra Mods
  62. What battery would you replace it with ?
  63. Fog Light only switch conversion???
  64. 07 high idle
  65. new round here
  66. TPS or Transmission--URGENT
  67. Repair Manuals
  68. ABS Light
  69. Timing Belt or timing chain?
  70. speedometer and tac not working
  71. New threads not being identified
  72. Is this normal
  73. Replacing Foglight bulbs
  74. Blower on high only
  75. Is Side and Curtain Air Bags Package Necessary?
  76. head lamps problem
  77. 2001 Xterra overheats sometimes
  78. Fuel economy
  79. Thinking of buying an Xterra
  80. help on transfer case (4x4) knob removal
  81. Xterra Bucking When Cold
  82. 2002 xterra pcv valve
  83. Sunfire electrical problem
  84. How to convert to 4x4?
  85. Fuel Tank problem
  86. 4X4 switch
  87. 2004 XE 2.4L / Any advice before I buy?
  88. AC problem
  89. Power window doesn't work
  90. nissan po420 code bank 1
  91. Another new Exterra owner
  92. New Xterra Owner
  93. All but driver window dead, relay problem?
  94. 2005 SE (19,000) vs. 2006 S New (21,500)-better deal??
  95. what should i do to it
  96. Brushguards
  97. Teraflex Revolver Shackles
  98. engine runs to cool
  99. Speedometer & Odometer
  100. Yakima lowriders and crossbars
  101. Future Owner Help Plz
  102. Xterra 2000 SHOULD I BUY
  103. Fuse Question
  104. Check Engine Light!!!!!!!!
  105. a/c haze and odor
  106. Coolant Disappearing
  107. Calmini shocks
  108. Where do I post xTerra for sale?
  109. A/C weird problem. Any clue?
  110. new owner
  111. Rooftop viewing platform
  112. temp gauge dance
  113. Squeak when hitting Bumps
  114. supercharge
  115. Need help identifying a part on a 2002 X
  116. Looking to buy my first car, an Xterra
  117. 02 Supercharged horrible mileage!!!
  118. new posts visible?
  119. 2006 off-road worth it?
  120. Keyless entry
  121. xterra 2000 temperature problem
  122. New Here
  123. Xterra Reliablity
  124. 2000 Xterra 4x4 SE FOR SALE
  125. 2000 nissan xterra
  126. cargo capacity (interior)?
  127. What is '06 dash made of & any way to remove scratches?
  128. Frame Welds
  129. A/C Leak
  130. Tire replacement
  131. Looking for: 02 Xterra Service manual
  132. Dimmer switch/tail lamps ?
  133. right front abs sensor
  134. Roof Rack Screws, need replacement nut inserts
  135. Honest oppinion of the latest Gen Xterra
  136. Question on Knock Sensor
  137. 2006 Xterra Pricing - about to buy
  138. Does your instrument panel go in and out?
  139. Nissan Xterra
  140. Thinking of Buying a 2006. Have some questions
  141. windshield wiper parts???
  142. click sound on 05 Xterra
  143. Leak over passenger door
  144. Help!
  145. 2003 Xterra SE For Sale in PA
  146. Keyless Entry only unlocks driver's door
  147. 2000 Xterra purchase.....advice?
  148. Replacing bulbs behind the a/c controls
  149. small leak
  150. 2001 Xterra Won't Start
  151. service engine light on...?
  152. O5 Water leak Rear Doors
  153. blower
  154. Serious Exhaust Issues
  155. How do you carry extra gas
  156. Problem with 4x4
  157. 6-Speed 2005 Shift Stick sticks
  158. Looking into buying a 05 or 06
  159. Preserving engine hoses
  160. noise from the engine compartment!
  161. 4cyl oil capacities 2003 Xterra
  162. Replacing Lifgate Interior Trim Panel
  163. 03 Xterra Driver Door not aligned?
  164. Glove Box Rattle
  165. warranty transfer
  166. AT Oil Temp Light
  167. speakers for 05 x
  168. Questions on Mats
  169. '02 X For Sale in West KY
  170. 03 Xterra engine failure
  171. How to?
  172. steering question for 05 X
  173. 2005 keys
  174. Hid
  175. Problem with Keyless Entry
  176. Hotter Than Hell - hot air through vents??
  177. oil preassure switch leak?
  178. Front Marker Light replacement???
  179. hows the 256 engine?
  180. Clanking Noise on breaking
  181. Loud noise from front end 2000 Xterra
  182. hill descend assist on '05 OR
  183. anyone put there 3" suspension lift in themselves.
  184. 05 X Tow Hitch SAFETY RECALL NOTICE
  185. so whats better off road. manual or auto
  186. modding a supercharged xterra
  187. Xterra Door Removal?
  188. 1988 izuzu rodeo / 3.2 dohc
  189. how to change front 2002 signal lights?
  190. Thread ratings on
  191. how to do a radiator flush?
  192. how to change tranny oil?
  193. Warrenty
  194. belts
  195. Better my gas mileage?
  196. compressor clutch
  197. 100k mile question
  198. K&n filter: will it help gas mileage?
  199. ticking
  200. Tires squeal
  201. just got my new x
  202. AC went south on me!!!!!
  203. air conditioner operation in defrost/defog mode
  204. Hi
  205. Rust on the back of my X
  206. windshield washer fluid reservoir
  207. Issues with new 05 OR X
  208. 2005 xterra speaker sizes
  209. hubs acting up?
  210. Stolen 2005 Nissan Emblem
  211. 2001 Izuzu Rodeo
  212. 2005 Xterra Steering Wheel ?
  213. New 05, 2nd XTerra, New Member, First 4x4
  214. Dash Problem
  215. hard knocking sound
  216. Hitch Install on 05 X?
  217. Changing the Timing Belt
  218. 2005 OffRoad Shocks
  219. 2005 Xterra - New Member
  220. towing my 2002 x
  221. what was nissan thinking when they put the alt at the bottom of the truck
  222. i need a rear bumper. where would i go besides the dealership
  223. how do , do a front brake job
  224. 2000 Xterra No A/C
  225. 2000 Xterra Timing Belt and Rattling/Vibrating Sound
  226. Lift
  227. new 05 xterra
  228. 05 xterra moonroof
  229. Xterra Boost Problem
  230. My X got HURT!!!
  231. 2005 Xterra - tickling sound
  232. 2000 Xterra General Questions
  233. Tow Hitch Wiring Questions on 05 offroad.
  234. Trouble Cold Starting After Injector Cleaning
  235. clicking noise on the drivers side
  236. Front Tow Hooks
  237. hot truck
  238. Trailer Hitch Wiring Bracket
  239. service engine soon light
  240. how much $$$ for a 00 xterra?
  241. help, help!
  242. Xterra 2000 emission failure CO too high
  243. heat shield
  244. brake shoes wear
  245. Tow Hitch Advice For Newbie
  246. Cabin microfilter info
  247. squeaky suspension
  248. a/c compressor
  249. AC problem
  250. Switching from 4wd to 2wd
